Ditch my posi?
Author Topic: Ditch my posi?  (Read 1309 times)
Offline 71chmark
Ditch my posi?
« on: January 22, 2006 - 03:00:09 PM »
I want to get some aftermarket heads like edelbrock rpm but I can only afford one. Since one side of the engine will be faster should I ditch my posi? Just kidding. Is this a good upgrade from the smog heads and also what exactly is a dakota throwout bearing?.
I may be schizophrenic,
Re: Ditch my posi?
« Reply #1 on: January 22, 2006 - 08:19:18 PM »
hard to say if it is a good upgrade without a lot more info on your combo 1st is this a small block or big block
Eddy Heads are not a true bolt on head , be prepared to do some work to get them on your engine , also if you have low compression now alum heads will  lose close to 1 point of compression which will Not help power due to heat loss to alum , you will need to use a top quality gasket as wel such as the Cometic gasket or be prepared to change head gaskets regularly generally speaking the Eddy heads will have better flow than production iron heads
 the Dak pilot brg is a roller brg not a bronze bushing , & it is pressed into an alum puck that fits int he Torque converter hub in the rear of the crank
 Definatly ditch the Posi , it is a GM part
« Last Edit: January 22, 2006 - 08:21:21 PM by Chryco Psycho »
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
Re: Ditch my posi?
« Reply #2 on: January 22, 2006 - 09:16:35 PM »
hahahahahahaha!
Offline Killer_Mopar
Re: Ditch my posi?
« Reply #3 on: January 22, 2006 - 10:02:34 PM »
Just upgrade your muffler bearings and you should be fine.....
Offline wart1de
    • Vivah
Re: Ditch my posi?
« Reply #4 on: January 22, 2006 - 11:34:10 PM »
 :roflsmiley:
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
Re: Ditch my posi?
« Reply #5 on: January 23, 2006 - 08:27:23 AM »
You'll also need a sky hitch adaptor for the Edelbrock heads before you install them. Oh, and don't forget to get the head alignment tool also.
Offline oldvamoparfan
  • MOPAR; The only way to go!!!!!!!
Re: Ditch my posi?
« Reply #6 on: January 23, 2006 - 08:40:06 AM »
Dont forget too add Hi-Po tail-light lenses & a Honda Civic exhaust tip.  This should add about 20 mph & take 2.5 sec off qtr mile times.   Ovmf
'72 Challenger 360,  '05 Dakota,   04 Town & Country,   '82 Yamaha 650 Maxim
Oldschool
Re: Ditch my posi?
« Reply #7 on: January 23, 2006 - 05:06:24 PM »
Just do the math and figure out the difference in power from side to side.  Then place unequal sized tires on the rear to compensate for it.  Wasn't that easy?   lol   :roflsmiley:   :cooldancing:   ....Oldschool
« Last Edit: January 23, 2006 - 09:41:52 PM by Oldschool »
Offline 71chmark
Re: Ditch my posi?
« Reply #8 on: January 23, 2006 - 08:07:46 PM »
I tried what everybody said and now my car only goes in a circle backwards
Re: Ditch my posi?
« Reply #9 on: January 23, 2006 - 08:41:17 PM »
You need a O-pipe and a 710 cap.....and you should be good to go again
kudakidd
Re: Ditch my posi?
« Reply #10 on: January 24, 2006 - 09:20:39 AM »
yep.
