Author Topic: So many harmonic balancers out there for sale today, which one?  (Read 1780 times)
Offline gomangoRT/SE
« on: January 24, 2006 - 07:40:47 PM »
There are harmonic balancers being sold by everyone.  Prices are from $29 to $300.  I understand the expensive balancers are made to withstand high RPMS without problems, but for your average everyday or weekend warrior who doesnt turn his moter over 5800 rpm is it justified to go out and spend alot of money on one.   I have seen alot of balancers in the $75 to $100 range, still when I take my rotating assembly to the machine shop I also take my stock balancer.
Re: So many harmonic balancers out there for sale today, which one?
« Reply #1 on: January 24, 2006 - 11:58:25 PM »
I just used a realtively Cheap new balancer , it was made too short & will not pinch the timing chain crank gear , the washer on the crank bolt bottoms on the crank snout before fully seating the balancer , we had to  machine the washer to go over the front snout of the crank about .020 to get the balancer fully seated
 I wil get the make of it
Offline Pistol Gripper
« Reply #2 on: January 25, 2006 - 04:46:42 AM »
I've seen ads for fluid dampers, are they worth it ?
P.G.
O ne
B ig
A $$
M istake
A merica
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #3 on: January 25, 2006 - 05:00:35 AM »
If you have your original, You could send it to a company called the "Dampner Doctor". They'll completely rebuild yours for about $90.
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
« Reply #4 on: January 26, 2006 - 12:26:37 AM »
the balancer I had problems with a is a Powerbond , possibly the same as the Pioneer one
 fluid dampers are worth the $$ as they have much less inertia to spin up & generally are high quality construction
Offline Autophile
  • Kowalski... and the keys to a sawed-off weekend!
« Reply #5 on: January 26, 2006 - 11:05:12 AM »
I just installed a Fluidamper over Christmas vacation. It is really nice quality, although I can't say that the engine feels any different... The reason why I upgraded my damper is that I have seen OEM style dampers fail previously on my 440. I think it was simply from the elastomer drying out from 30 years of use. Oh, and I bought a good installer/remover and a nice ARP bolt along with my Fluidamper. I wasn't going to tap this sucker with a hammer..  ;)
« Last Edit: February 05, 2006 - 04:24:51 PM by Autophile »
1971 Cuda, black/black, 419 cu. in. 3G Hemi with twin turbos (build in progress), AlterKtion, Wilwood 12.19" disks, billet Rallye wheels
Offline matt63
« Reply #6 on: January 27, 2006 - 05:45:40 PM »
I bought one of these too.  I believe they are Australian made and are supposed to be better than some of the other "offshore" stuff and alot less than the ATIs.
Matt in Edmonton
'68 Valiant
