Author Topic: Questions about color and undercoating  (Read 3899 times)
Offline Steve
  • I Love Welding!
« on: January 25, 2006 - 09:20:24 AM »
OK...I'm not doing a concourse resto, but I would like to make the car look original. Let's talk undercoating. I need some input. I plan to use a modern sound-deadener and/or truck bed lining for undercoating the underside of the car, the wheel wells, and inside the doors and quarters. Here are my questions:
First, when doing the underside, how much should be covered? From the tail panel to the front lip on the firewall? As for side to side, would you go from lip to lip, or just inside the frame rails? Would you include the frame rails? As for color, I suppose I can leave the undercoating black or topcoat with Zero Rust dip gray primer or even apply body color. Opinions?
Second, when doing the wheel wells, was the undercoating in the wheel wells left black or was it covered in body color? Also, for the front wheel wells, would you include the area where the suspension attaches or would you mask that off and cover just the sheetmetal portion of the inner fender well (we're talking on the fender side, not on the engine bay side). Opinions?
Third, the quarters were covered in sound insulation of some type (undercoating I guess). I believe this was painted body color, but can someone confirm or deny that? If so, I plan to cover the inside quarters in Zero Rust, then cover with the trunk bed liner, then spray body color when doing the trunk. Opinions?
I'd like it to look original (at least from a distance) but I'm not opposed to some deviation if it would increase functionality or appearance.
Thanks!
Offline Mopar73340
Re: Questions about color and undercoating
« Reply #1 on: January 25, 2006 - 04:32:25 PM »
Steve I'm not a expert on the undercoating so I'll leave that question for someone else, I chose to do my entire undercarriage with black from Eastwood. Also I don't think it's a good idea to paint over undercoating in the trunk. I attached an example of how my trunk looked before restoration where someone decided to paint over the undercoating. Hope this helps.
« Last Edit: January 26, 2006 - 02:08:27 PM by Mopar73340 »
Offline crcarch
  • Happiness is having the time and the money!
  • "No, it's not a Charger!"
    • A little history and restoration pics on Cardomain
« Reply #2 on: January 26, 2006 - 07:16:01 AM »
I'm not an expert either, but I can tell you what mine came from the factory with.
Undercoating was installed in varying thickness from the firewall back and from rocker to rocker.  Front and rear wheel wells were also undercoated black.  The only thing not liberally sprayed was the suspension and tubing.  The trunk interior had sound deadener sprayed low in the quarters and the rest of trunk was body color.  Trunks were very utilitarian back then.  With the jack and tire just sitting out.  My jacking instruction sticker was even slapped on the lid diagonally! Quick and sloppy work. It wasn't pretty.
Unless you're building a show car, I wouldn't recommend painting the wheel wells body color.  Your tires will look smaller, especially with a bright body color and won't look right-sized without the black.  I'm fixed this on my wife's new Crossfire.  It's got 19" wheels that look like little donuts because they left the wheel wells body color and it's yellow.  I blacked out the wheel wells and it made all the difference.
One other thought.  If you are stripping it all off you may want to consider using Rhino liner on the underside.  Troy Trepanier used it on "Sick Fish" and it looks great.  He chose it because it's indestructable and easy to keep clean since it's hard and not gummy.
00/===\00 73 Challenger 440-4V/AT  8/--+--\8 09 Ram 1500  0o\==/o0 05 Crossfire Roadster OO(#####SRT)OO 10 Challenger
Offline Steve
  • I Love Welding!
« Reply #3 on: January 26, 2006 - 07:56:42 AM »
Thanks for the input! I think you're right about leaving the wheel wells black! I plan to use Rhino or something similar. Also, I didn't know how much coverage was put on the underside. Sounds like they covered a lot! OK...Black truck bed liner on the entire underside and wheel wells (front and rear). Something tells me that the sound deadener in the quarters was covered in color...I plan to do that, too, using the truck bed liner on the inside of the quarters, the dust with color.
Offline cudaaah
  • 71 HEMI cuda, 2015 ram 2500 mega cab diesal 4x4
« Reply #4 on: January 26, 2006 - 08:58:07 PM »
You may want to compare Rhino w/ Line-X.   I don't claim to be an expert either, but I had line-X on a truck I had, and heard from various people that it was better than Rhino...I wouldn't know.  I was amazed w/ the strength and the way it held up under use. Good luck, and I may do the same w/ my resto I'm starting.
Cudaaah
Offline crcarch
« Reply #5 on: January 27, 2006 - 06:55:35 AM »
I've heard more issues about installers than the products themselves.  The only issue I've ever heard against Rhino liner is that it had a fading problem, but they've since reformulated it to hold up better against UV.  I've had it for 2 years in my Ram worktruck with no problems and it still looks good.
I think you'll be fine either way.
Offline Steve
  • I Love Welding!
« Reply #6 on: January 27, 2006 - 07:56:43 AM »
That good feedback guys! Thanks! Once I get in the connectors, I plan to lay on the undercoating, then I can weld on the quarters and get the car off of the rotisserie! That thing just takes up soooo much space in the garage!
Offline cudaaah
« Reply #7 on: January 27, 2006 - 01:27:28 PM »
one last thing, I heard that w/ rhino, the color is sprayed on, ( may not be the case w/ black ) where as line-X the color is w/in the material itself.  again it's been 6-7 years since I had this done..All may be different now.
Good luck w/ you project
Cudaaah
Offline crcarch
« Reply #8 on: January 27, 2006 - 01:33:46 PM »
I have a black bedliner so I don't have definite answer, but as far as I know the color is integral with Rhino.
Offline common 27
« Reply #9 on: January 28, 2006 - 07:12:15 AM »
Very interesting idea about the undercoating.I'm wondering if the underside needs to be blasted to bare metal to get it to stick or does it only need to be clean and free from grease and oil?
1970  Challenger Convertible   1968 Satellite Convertible
Offline crcarch
« Reply #10 on: January 28, 2006 - 09:17:54 AM »
Since they did nothing but clean my bed before applying, I'd say that's all that has to be done.
Offline common 27
« Reply #11 on: January 28, 2006 - 01:54:15 PM »
 :ylsuper:By the wat crcarch  That car is awesome Is it finished yet? More pics please!
Offline shatar4
  • 71 Challenger
« Reply #12 on: January 28, 2006 - 03:07:30 PM »
I used Lizard Skin for the underside of mine. http://www.coollizard.com/pages/products.htm I did not do my frame rails with it. I used POR-15 on the rails
1971 Triple black 340 Challenger
Offline crcarch
« Reply #13 on: January 28, 2006 - 03:39:34 PM »
Thanks for the compliment. Nope, it's not finished yet.  Not even back from paint. (Sore subject)  I finished paying the A-Team at the end of the year with the promise that it would be finished by Jan.1..... :banghead:  I'm still trying to rub "SUCKER" off of my forehead.  You can see the current status on my web page http://www.cardomain.com/ride/2133982.
Offline cudaaah
« Reply #14 on: January 28, 2006 - 10:13:30 PM »
As far as what has to be done B4 applying undercoat, if your talking about the rhino/Line-x, I believe they'll have to scuff up any suface.  when they applied to my truck, they sanded/scuffed the entire bed B4 applying.
