Author Topic: Need oil pan advice  (Read 5715 times)
Offline Killer_Mopar
Need oil pan advice
« on: January 25, 2006 - 06:20:29 PM »
I am ready to purchase the rest of the parts I need for my ending this weekend, however I have run into another wall. I want to know if anyone is running an aftermarket oil pan and if so, what kind and how is it??? I basially want an oil pan with a 1-2 qt over stock reservoir because I am going to run a high volume oil pump, however I dont want the pan hanging out under the car and for that matter, I dont even want it to be noticable. Does anyone know of a pan that fits my parameters??? Thanks
Offline todd383
  • I'm a llama!
Re: Need oil pan advice
« Reply #1 on: January 25, 2006 - 06:47:21 PM »
Hay killer, i am running a milodon low profile 7 qt. oil pan,  i have no problems what so ever, clearance is no problem, and i am runnin tti headers 17/8 headers, again , no problems.
Offline GoMango
« Reply #2 on: January 25, 2006 - 07:45:55 PM »
Another option that kinda the stock route is to get the 6qt 440/Hemi pan...
70 Challenger R/T
(Back on the road--1st time since '96)
kudakidd
« Reply #3 on: January 25, 2006 - 07:48:39 PM »
IF he's running a big block. Also, whatever you buy don't go with a chrome oil pan.
Offline gomangoRT/SE
« Reply #4 on: January 25, 2006 - 07:53:33 PM »
I am in the same quandry as Killer.   LIke him I am running a high volume oil pump and want a few extra quarts in my oil pan.   On ebay I am seeing alot of 7 quart oil pans for around $60.   They dont look deep.  Has anyone purchased any of these.   If my memory is correct Mopar is nailing you for like $140 plus on the 6 quart oil pan.   That seems steep for just an oil pan.
Offline GoMango
« Reply #5 on: January 25, 2006 - 08:05:40 PM »
I haven't had to buy 1 of the Mopar 6qt's in a while--didn't realize they got so expensive :22yikes: The milodon might be the best for the money.
70 Challenger R/T
« Reply #6 on: January 25, 2006 - 08:16:31 PM »
Forgot to say that this was going on a stroked 400.....
Todd383, did the milodon use the stock pickup???
« Reply #7 on: January 26, 2006 - 12:40:24 AM »
Milodon 35180 , pick up is 18328
Offline todd383
  • I'm a llama!
« Reply #8 on: January 26, 2006 - 05:09:53 AM »
No it didnt use the stock pick up, get the milodon one, and they also have a windage tray too,
Offline pandamarie
  • I love YaBB 1G - SP1!
« Reply #9 on: January 26, 2006 - 10:29:50 AM »
I have a 7 quart milodon on my 70 challenger 440 and it does hang down below the k frame and I have ripped a hole in it once, bottomed out after going over the crest of a cross street at about 60mph other than that I havent had any problems, im also using the milodon high volume oil pump with the 1/2 inch pickup and I would suggest using the fram HP1 oil filter as the standard filter fram PH8A blew up first time I took it to 6500rpm. no problems with the HP1s.
1938 packard 120
1948 lincoln convertible coupe(1 of 16)
69 charger
70 challenger R/T 440 6 pac
71 challenger 340 R/T 4 speed
2-1961 nash metropolitans
forgive wifes 75 vette
2002 dakota 4.7
« Reply #10 on: January 26, 2006 - 02:25:24 PM »
Im assuming you meant 31580 because I couldnt find a "35180" and the 18328 pickup is made for a "31580" oil pan according to summit. The oil pan looks pretty nice, however it cost 365 bucks and the pickup is another 70....too expensive for my linking. Thanks for the suggestion through.
Yeah, I heard to many horror stories about Fram.....I plan on using K&N or Wix filters with the new engine.
Is anyone running the Milodon 30930 oil pan on there cars??? Pretty decent price and it holds 7qts......
http://store.summitracing.com/default.asp?target=partdetail.asp&autofilter=1&part=MIL%2D30930&N=115+4294908110+4294840045+4294908395+4294840062&autoview=sku
« Last Edit: January 26, 2006 - 02:37:22 PM by Killer_Mopar »
Offline todd383
  • I'm a llama!
« Reply #11 on: January 27, 2006 - 11:32:25 AM »
Hey killer, i think your lookin at the wrong thing, i bought mine from jegs,pt#,697-30930 and i paid 170.00 bucks for it and a 3/8 pickup pt.#697-18325, 35 bucks, and i think the windage tray was 50 bucks, i dont have my receipe for that, all under 300.00.
« Reply #12 on: January 28, 2006 - 10:18:00 AM »
Nope, was looking at the right pan. The 35180 is over 350 bucks just for the pan. The one you mentioned is the one I found on summit for 173.88.....I think that is the one I am going with.
Offline ntstlgl1970
  • T a c o c a t
« Reply #13 on: January 28, 2006 - 10:59:00 AM »
I ended up buying the milodon pan from summit with the pickup. I haven't put the engine back in the car yet, but this pan seems to be the only other option for a pan that doesn't hang below the k member on a big block besides the hemi pan. There is no comparison between the factory baffles and the trap door setup in the milodon pan. If you have access to a welder or know someone who is a good welder you can buy a road race sump kit from moroso for around $150 and weld it to your pan core yourself. Then I sold my stock oil pan, windage tray, pump and drive on ebay for close to $100 to offset the cost of the milodon pan/pickup and windage tray.
« Last Edit: April 10, 2006 - 05:47:07 PM by Rev-It-Up »
« Reply #14 on: January 28, 2006 - 11:29:14 AM »
Ntstlgl, what is the part number of that oil pan??? It doesnt look like the 30930......
