Author Topic: Conversion from 318 to 440  (Read 1212 times)
Offline zerfetzen
  • 'Cuda, should'a, would'a...you lost.
« on: January 27, 2006 - 07:25:30 AM »
It'll be a while before I can pull this off, but I might as well plan early...
A local MOPAR guy was telling me that to convert from a 318 to a 440 in my 73 Cuda, I won't need to change my driveshaft or motor mounts.  Is that right?
I know I'll need a 727, but it seems funny that the driveshaft and motor mounts would be the same.  Thanks.
cudahob
Re: Conversion from 318 to 440
« Reply #1 on: January 27, 2006 - 08:30:04 AM »
I don't think that is right, you'll get a better answer from the next guy. v
I would change the drive shaft, to a bigger style yoke and U joints. I would also change your yoke on your chunk to that too.  Especially if your 440 is horse power hungry, they like U joints.
They make a two sided u joint that would work, but I wouldn't mess with that.
« Last Edit: January 27, 2006 - 08:33:26 AM by cudahob »
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: January 27, 2006 - 08:46:07 AM »
I would say that the motor mounts are different also but the K frame will be the same!   :wave:
Offline zerfetzen
« Reply #3 on: January 27, 2006 - 10:46:14 AM »
Thanks, I knew it had to be.  Just checking.
« Reply #4 on: January 28, 2006 - 02:35:20 AM »
if the 318 had a 727 trans behind it it si possible to use the same driveshaft , if you have a 904 trans behind the 318 which is more common neither the slip yolk or the driveshaft will fit
 , the K frame is the same but the 440 needs different mounts as 4C said
