Author Topic: Anybody repop BS  (Read 1315 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
Anybody repop BS
« on: January 28, 2006 - 07:37:48 PM »
Is it possible to get a broadcast sheet redone?
SOLD
Offline hemi71
Re: Anybody repop BS
« Reply #1 on: January 28, 2006 - 08:46:24 PM »
You can find blanks on e-bay from time to time...but a redone Broadcast sheet with all the options typed in?  Sounds like that might be opening pandora's box...no matter how honorable your intentions are. There are too many people out there who would just love to be able to build a broadcast sheet with all the good "stuff".
That said, i do believe there is a guy who has blanks and will make one up for you...but it's going to be $$$$$ to do it.
[attachment deleted by admin]
« Reply #2 on: January 28, 2006 - 09:20:41 PM »
I always forget the dark side of people. I do have some blanks and I have been able to fill in alot of my stuff my BS was glued to the floor and will need to be taken off when its time for paint.
« Last Edit: January 30, 2006 - 10:03:29 AM by Rev-It-Up »
SOLD
Offline Andrew
« Reply #3 on: January 28, 2006 - 11:33:52 PM »
Cant you just clearcoat (or some other transparent stuff) over it?
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #4 on: January 29, 2006 - 03:56:00 AM »
There is a guy over on Moparts that will do them but not sure of his username.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Swedefish
« Reply #5 on: January 29, 2006 - 04:21:27 AM »
Is there not any way to scan it of the floor with some sort of mobile scanner? At least then you have a copy of the original BS although it`s not complete.Better than nothing ,wich`s the case for me.
« Reply #6 on: January 29, 2006 - 09:52:40 AM »
I have taken several pictures of it. I am not sure you could even clear coat it the BS is so brittle the brush stroke would probably just pull it apart.  :faint:
SOLD
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #7 on: January 29, 2006 - 11:32:30 AM »
I'd try and preserve the original right where it is..................there is a clear coat in rattle bomb form, with a little practice on other paper objects it may be worth a try.............noting to loose. Good luck.
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #8 on: January 29, 2006 - 08:22:29 PM »
I agree, try to save what you have.
Can you not find another one in the car anywhere(like in the front seat backs)?
2013 Tige' RZR 343hp
« Reply #9 on: January 29, 2006 - 08:28:18 PM »
no other build sheet and have the car pulled apart all except the dash but I have looked under it and do not see another. I will take good pictures and be thankful that I now know what kind of wheels my car came with.
 Since most La cars did not have any build sheets I should be happy I will end up with a picture and some torn fragments.
SOLD
« Reply #10 on: January 30, 2006 - 07:33:29 AM »
Your dash,............just maybe? When I stripped my Charger for the resto I found my build sheet under the front bucket a rather typical place, but when the dash was removed, taped on top of the clove box insert was another build sheet. Now here is the irony in this, the sheet taped to the clove box was not for my Charger  ? Either the dash in my car was actually intended for another Charger on the production line or too perhaps someone over the years replaced the clovebox insert with one from another car? At any rate check it out, it may be on top of that insert and you will not see it by just looking under the dash  ??
1970 Charger 500
1971 Dart Swinger
1973 Challenger
