Hemi idea
Author Topic: Hemi idea  (Read 4541 times)
Offline hemi-5.7-cuda
Re: Hemi idea
« Reply #15 on: January 29, 2006 - 11:08:33 PM »
You can check out my conversion on Newb Intros.
71 Cuda Conv Project.
thankx
hemi-5.7-cuda
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
Re: Hemi idea
« Reply #16 on: January 29, 2006 - 11:12:56 PM »
I will, thanks...
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
Offline ESGEE
    • SG´s site
Re: Hemi idea
« Reply #17 on: January 31, 2006 - 08:06:47 PM »
I have now found a 5.7 with carb, the thing is i dont know what intake it is so know its time to attack the firm :bigsmile:
70 Charger 500
Offline 57hemicuda
  • 5.7 hemi
Re: Hemi idea
« Reply #18 on: January 31, 2006 - 08:17:46 PM »
If done right,I think the new hemi increases the value of your car.I just finished putting a 5.7 in a 70 cuda ragtop,  http://mysite.verizon.net/ls6ron/  and i'm getting ready to do a 6.1 hemi in a hardtop.Its not that bad of a conversion
Offline ESGEE
    • SG´s site
Re: Hemi idea
« Reply #19 on: January 31, 2006 - 08:33:39 PM »
Great site there, i dont have the money to do all that so im gonna keep it stock. Now im just thinking in the trans, should i get a 6-speed thats for it or go with the 727...
70 Charger 500
Offline GoMango
Re: Hemi idea
« Reply #20 on: January 31, 2006 - 08:46:11 PM »
Great site 57hc and 1 cool Cuda :wow: Got a question, how did the 727 hook up to the late hemi? Adapter plate or other?
70 Challenger R/T
(Back on the road--1st time since '96)
Offline 57hemicuda
  • 5.7 hemi
Re: Hemi idea
« Reply #21 on: February 01, 2006 - 04:36:03 AM »
Bolts right up to small block bellhousing had to make a flex plate, and use a spacer between block and trans
Offline ESGEE
    • SG´s site
Re: Hemi idea
« Reply #22 on: February 01, 2006 - 08:20:24 AM »
Was it hard to make, or do you have to be a real master mechanic?
70 Charger 500
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Hemi idea
« Reply #23 on: February 01, 2006 - 11:51:20 AM »
Nice car, 57hemicuda!  :thumbsup:
Offline 57hemicuda
  • 5.7 hemi
Re: Hemi idea
« Reply #24 on: February 01, 2006 - 01:35:38 PM »
The hemi crank is 8 bolt instead of 6,but its not the same bolt circle as the old 8 hole hemi crank,so had to machine a new flex plate.The crank to block spacing is about .100 taller on the hemi so had to use a spacer between block and trans.the spacer is the factory peice that came with my hemi.someone will certainly produce a flexplate soon,suprised mopar doesn't have one yet
Offline ESGEE
    • SG´s site
Re: Hemi idea
« Reply #25 on: February 01, 2006 - 02:50:57 PM »
Ok, thats great to know. And i do hope they do make the stuff soon...
70 Charger 500
Offline ESGEE
    • SG´s site
Re: Hemi idea
« Reply #26 on: February 04, 2006 - 06:19:31 PM »
I know that they used a intake on the crate 5.7 Hemi called M1 but its a 440 intake(when i have searched the web for it) is that right, that an preformence 440 intake fit right up on the 5.7 Hemi? Does anyone here know?
70 Charger 500
Offline wart1de
    • Vivah
Re: Hemi idea
« Reply #27 on: February 05, 2006 - 04:45:12 PM »
You can say that again! Awesome!
 :ylsuper:
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
Re: Hemi idea
« Reply #28 on: February 06, 2006 - 05:02:01 PM »
Hay:
Pink Panther.
Was your car originaly Pink? Do you get a lot of nuts about it being pink. I love the color it defantly stands out.
I thought about painting my pink but I know everyone at work would give me a hard time. If it was pink when I got it there would be no question it would go back pink.
Do you regret the pink?
What is the paint code for the panther pink?
 :cooldancing:
hemi-5.7-cuda
The code for Panther Pink, or moulin Rouge is FM3.  All you have to do is tell the gys at work that it takes a real man to drive a pink car!!!!
Offline 57hemicuda
  • 5.7 hemi
Re: Hemi idea
« Reply #29 on: February 06, 2006 - 05:41:51 PM »
The m1 intake is just mopar performances name for there high performance intakes.There are m1 big block,small block, hemi, etc.intakes called m1's, but no a 440 intake won't fit a new hemi.I've got the part # of the hemi m1,but its not avalible yet,you can only get it on the crate engines right now.I'm sure edelbrock and others will have some good intakes soon.Ron
