Those are 14", MEK? They look real nice for 14"s!
A lot of times the 14" Rallyes look small.
Hey Oz, I don't know how much it costs to widen the rims but Summit Racing has repros that about $130 each but they may be in chrome. If you have the factory Magnums, they may be more like brushed steel center with an unfinished outer ring part that'll require trim rings. Or do you have chrome?
The Paddock (
www.paddockparts.com) has both chrome and the other style but the center section is painted aluminum, not brushed steel. For about $150-$165 depending on size/style you have. Keep in mind that center caps are an extra cost, plus rings if you have to get them. The factory brushed rings from the Paddock are $90/each! Yikes!!!!
Either way, if you don't get a whole set of rims and only get 2, then you may have trouble matching them, but you may not be able to tell from 20'. Also the trim rings you have will have a gap between the ring and the center section of the wheel if you chose to use those.
I know, decisions, decisions, I went through the same thing.
Do you definately want to stay with 14"? Only Magnum style? Are you looking to keep the factory look?
