Author Topic: 295/50-15??  (Read 5327 times)
Offline bennydodge
295/50-15??
« on: February 02, 2006 - 07:37:59 PM »
Has anybody tried running this rear tire/wheel combo? 295/50-15 on an 8" wide ralley wheel with 5" backspace. This would be with the leaf springs in the stock location. Car is a 73 Challenger.
1973 Dodge Rallye Challenger 340(416 stroker), 727 ,3.23 SG, 76,xxxmi.
2010 Ram 3500 CC Dually 4x4, Cummins, loaded
2015 Challenger R/T classic B5 5.7 8spd
Offline EVIL72
Re: 295/50-15??
« Reply #1 on: February 02, 2006 - 10:12:30 PM »
  I think 4" backspace is the sweet spot with an 8" rim, but I have 15x8.5 Centerlines with 4 7/8 back spacing and 295/50/15 BFG's on the back of my 72 Challenger with a stock rearend. They were 1/16th's to 3/16th's from the leafspring so I had to use 3" long ARP wheel studs, open end lugnuts and Mr. Gasket 7/16th's wheel spacers to get the clearance to at least 1/2 inch from sidewall to leafspring.
« Last Edit: February 02, 2006 - 10:14:19 PM by EVIL72 »
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Re: 295/50-15??
« Reply #2 on: February 03, 2006 - 12:19:49 AM »
I agree , 4" or 4 1/4 fits perfectly
Offline crcarch
  • Happiness is having the time and the money!
  • "No, it's not a Charger!"
    • A little history and restoration pics on Cardomain
Re: 295/50-15??
« Reply #3 on: February 06, 2006 - 07:57:29 AM »
That's close but it may not be enough. On my '73 that would put the sidewall 3/8" off the spring but flush with the fender lip. Depending on how high or low your car sits in the rear, you may end up having to trim the lip slightly to prevent rub. See my reply to this thread. http://www.cuda-challenger.com/cc/index.php?topic=16197.0
00/===\00 73 Challenger 440-4V/AT  8/--+--\8 09 Ram 1500  0o\==/o0 05 Crossfire Roadster OO(#####SRT)OO 10 Challenger
Offline 73 challenger 440
Re: 295/50-15??
« Reply #4 on: February 11, 2006 - 02:12:53 PM »
got my wheels, here is a pic of one.. I just called tire rack to order my eagle gt's.. these have a sectional width of 12.1 and a tread width of 11.0.. I know some guys on here run the bf goodrich and firestone. but it seams that the wider the foot print the taller the tire.. I didn't know that.. so for me to go with the eagles it would raise it about a half inch compaired to the bf goodrich tire.. so that half inch of height could cause a problem.. not sure now if I want to trust getting them..  is there anybody else out there that run the 295/15's using other brand tires????
Re: 295/50-15??
« Reply #5 on: February 22, 2006 - 05:05:38 PM »
well, got the tires on, these tires have a 11inch tread width.. fits in there no problem..
« Last Edit: February 22, 2006 - 09:05:02 PM by 4cruzin »
Re: 295/50-15??
« Reply #6 on: February 22, 2006 - 05:07:38 PM »
sorry about the multiple post, it said it session timed out.....
Re: 295/50-15??
« Reply #7 on: February 22, 2006 - 05:10:32 PM »
thats wide!!!!
Re: 295/50-15??
« Reply #8 on: February 22, 2006 - 05:16:43 PM »
one more
« Last Edit: February 22, 2006 - 09:04:11 PM by 4cruzin »
Offline EVIL72
Re: 295/50-15??
« Reply #9 on: February 22, 2006 - 06:24:23 PM »
 Looks great! :thumbsup:
How much room did you end up with from sidewall to leafspring?
What leafsprings are those? And are you going to roll the inner lip up?
ROB
Re: 295/50-15??
« Reply #10 on: February 22, 2006 - 07:40:43 PM »
I should of took measurements, but I would guess close to 2 inches from leaf spring, and it may not appear I have room from the lip, but I sat on the back of the trunk and my dad still had about 2 fingers before fender lip... I have a pretty stiff susspension, so I doubt very much if it wil ever rub, if it should I'll just slightly roll the lip. but I really doubt that I will have to... I know they guy I bought it off of, had changed the front and rear springs, but I dont know what he used...
Re: 295/50-15??
« Reply #11 on: February 22, 2006 - 08:11:41 PM »
heres another
Offline EVIL72
Re: 295/50-15??
« Reply #12 on: February 22, 2006 - 11:43:46 PM »
 Great choice of rims and tires. Did it turn out how you wanted it to look?
 You got any whole car pics with the new meats?
ROB
Re: 295/50-15??
« Reply #13 on: February 23, 2006 - 01:38:54 PM »
no, I dont yet, but I love the look, I didn't want to keep them all on, because my car sits out side over the winter, and untill spring when I return it to the road, I want to avoid any bit of discoloring, so I dont need to polish, as it is now I have my carbs and manifold to repolish...
Re: 295/50-15??
« Reply #14 on: February 26, 2006 - 09:58:34 AM »
went to throw them all on, for a quick pic.... I am going to set the front lower, the old tires were 25 inches tall, so to avoid smacking the 7 quart man on the ground along with the headers, it was raised.. so i believe it's a matter of adjusting the torsion bar.
:villagers:
