Author Topic: Brake Booster  (Read 1195 times)
Offline MR291
Brake Booster
« on: February 05, 2006 - 05:31:28 PM »
Hi,
I'm redoing my '70 Cuda and was wondering if this is the correct booster for my car.  I can not find the part numbers.  Also, is there someone that rebuilds these?
Thanks.
Jerry
« Last Edit: March 16, 2006 - 09:44:05 PM by Rev-It-Up »
Re: Brake Booster
« Reply #1 on: February 05, 2006 - 05:35:54 PM »
looks correct
We have a rebuilder here ..KBR
Offline Carlwalski
Re: Brake Booster
« Reply #2 on: February 05, 2006 - 07:51:52 PM »
looks correct
Would it fit a my 440 Challenger Chryco?  :dunno:
My brake setup from MPBrakes has too much vacuum and bites a little when your not ready.
We are going to replace it with an original booster, problem is I sold my original one last year.  :banghead:
My car is rear drums front discs.
Cheers  :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Re: Brake Booster
« Reply #3 on: February 05, 2006 - 09:51:45 PM »
not sure how that would work by comparison to what you have now
Offline Carlwalski
Re: Brake Booster
« Reply #4 on: February 05, 2006 - 09:53:57 PM »
If it helps I ordered this exact kit from MBrakes.  :)
http://www.mpbrakes.com/db1304php.htm
Re: Brake Booster
« Reply #5 on: February 05, 2006 - 10:54:37 PM »
so how can I tell how efficient a booster is from a picture ??
Offline Carlwalski
Re: Brake Booster
« Reply #6 on: February 05, 2006 - 11:38:06 PM »
Not sure CP...I only stated that "If it helps" sheesh...... :-\
« Last Edit: February 05, 2006 - 11:40:07 PM by NZ440R/T »
Offline MR291
Re: Brake Booster
« Reply #7 on: March 19, 2006 - 08:09:22 PM »
Got my booster back from Power Brake Booster Exchange AKA "Booster Dewey" in Portland.
They did a fantastic job.  Quick, curtious and helpful.  Even has a year long warranty.
It should always be this good.
Jerry
