Author Topic: 1 inch shackles  (Read 949 times)
nivvy
1 inch shackles
« on: February 06, 2006 - 01:05:26 PM »
I think someone on here had a pair...where do you get them...and will they just bolt right on to my existing 3/4 relo kit and superstock springs....
8 Pack
Re: 1 inch shackles
« Reply #1 on: February 06, 2006 - 01:58:00 PM »
1 " offset ?
B & E body are P4120076 from Mopar
Offline Mt.St.BigBlock
Re: 1 inch shackles
« Reply #2 on: February 06, 2006 - 07:35:48 PM »
Hi 8Pack,  Check here,  members.aol.com/doctordiff/other.html
also Just Suspension is showing offset shackles in their ads now, don't  know if they're
a full one inch offset or not. I'm considering going with the Doctor Diff set up
to go along with a b-body rear housing I've already picked up.  Jeff
71 cuda 383 3spd manual gy9
Offline ChallengerVert
Re: 1 inch shackles
« Reply #3 on: February 07, 2006 - 02:58:28 PM »
I am not sure if the MOPAR and DOCTORDIFF is the exact same width, but the DOCTORDIFF relocation kit on in an E-Body with a B-body rear end lines up perfect and bolted right in.  A friend of mine had the B-Body rear with MOPAR relocation kit on his Cuda and it took some serious tweaking to get them to fit.
I highly recommend DOCTORDIFF kit.
1970 Dodge Challenger Convertible 493 6 Pack, 4 Speed
1971 Dodge Demon 408 5 Speed
