426 and 440 motorparts
Author Topic: 426 and 440 motorparts  (Read 1052 times)
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
« on: February 07, 2006 - 10:50:09 AM »
Once again a Hemi topic by me :bigsmile: I wonder what parts are the same on the 426 and the 440, i know fuelpump, timing, oilpan, oilpump and waterpump houseing are the same but what more, i know that heads dont match, but what does....
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
Re: 426 and 440 motorparts
« Reply #1 on: February 07, 2006 - 11:16:46 AM »
block ,heads ,cam ,con rods are unique , you can use a 440 crank , windage tray from a 440  , virtually nothing esle beside what you listed
Offline ESGEE
    • SG´s site
« Reply #2 on: February 07, 2006 - 11:26:53 AM »
That the block and rods are unique that did i know, but the crank and windage tray that i dident know thanks Chryco, i was thinking in buying a poor 426 block and put in the garage and in some years you have a 426 :bigsmile:
Then that i have a not soo good 440 without heads(thou crank look good) that i can take parts from dont makes things harder either...
70 Charger 500
« Reply #3 on: February 07, 2006 - 11:28:25 AM »
I would buy a new block , all the old ones are so beat up now & even the old ones are virtually the same price as new
Offline ESGEE
    • SG´s site
« Reply #4 on: February 07, 2006 - 11:41:52 AM »
Is it that bad, ok i know that all are like 0.30 over. Its just a sick childhood dream to have real 426 block and heads...  :burnout: I will never afford to buy new stuff, and i dont care if it take 10 years and sure it will cost 15k before its running but to pay allot for a crate Hemi is way out my pricerange.
« Last Edit: February 07, 2006 - 11:50:40 AM by ESGEE »
70 Charger 500
Offline ESGEE
    • SG´s site
« Reply #5 on: February 07, 2006 - 08:14:59 PM »
Got this from Troy on Charger....The Hemi crank has 8 bolts vs 6 for the RB. The balancer and all the pulleys are different as well due to the thickness of the balancer. The Hemi used a 3 bolt cam but I'm almost positive you can use a 2 bolt(?) cam in one if you change grinds.
I have to say that many parts from a 440 will physically bolt on but they aren't necessarily "the same". Water pump housings are interchangeable but the stock ones were different. The Hemi used a bigger stock oil pan but many people use the higher capacity pan on 383s and 440s already so they'll interchange. The Hemi actually used a different bellhousing, starter, and flywheel on the 4-speed cars. You can use the 6 bolt flywheel, bellhousing, and starter (as a set) if you drop in a 440 crank to match. The autos had a different flexplate for the 8 bolt crank as well but can be interchanged just like the 4-speed stuff. I think timing chain covers are the same and an RB distributor should fit.
70 Charger 500
« Reply #6 on: February 07, 2006 - 11:05:43 PM »
yes timing cover & dist swap , the cranks will swap but as you siad the Hemi is 8 bolt which is no big deal , 6 bolt stuff is easier to get & generally cheaper
« Reply #7 on: February 08, 2006 - 12:27:47 AM »
BIg block & Hemi cams are both available in 1 bolt or 3 bolt design & most grinds can be purchased on either , But Hemi cams & 440 cams do not swap from one to the other
