Author Topic: front sway bar from 71 RoadRunner??  (Read 1690 times)
Offline jshoop
  • I'm a llama!
« on: February 07, 2006 - 05:40:10 PM »
Will a front sway bar from a 1971 RoadRunner bolt onto a 1970 Challenger?  Is anything different about them?  I know the inner fenders are the same.  What about the suspension?
Re: front sway bar from 71 RoadRunner??
« Reply #1 on: February 07, 2006 - 10:47:44 PM »
Same , it will fit
Offline jshoop
  • I'm a llama!
« Reply #2 on: February 08, 2006 - 04:57:11 PM »
Great!  I know where I can get one of these!
« Reply #3 on: February 09, 2006 - 12:36:53 AM »
71-72 B bodys use the same part , hit the wreckers , 73-74 are different
Offline jshoop
  • I'm a llama!
« Reply #4 on: February 19, 2006 - 07:47:48 PM »
What about the rear sway bar?  My buddy got the inner fenders k member, radiator supportbrakes, etc off of a 71 RR (I think it was 71 have to make sure) He said I can get the front sway bar off of it.  The rest of the car is still at the yard.  He got the vin# and thought that it was a hi-po 383 four speed car.  I think he said some one took the rear end out (I think he said it had a dana at one time) of it but I'll check and see if the sway bar might still be around (if it had one).
« Reply #5 on: February 19, 2006 - 11:11:26 PM »
the rear is totally different , E body bars were body mounted & linked down to the springs , the B body was diff mounted & linked to the body which is the poorer way to design it
Offline jshoop
  • I'm a llama!
« Reply #6 on: February 20, 2006 - 04:17:25 PM »
Thanks for the info!
Offline jshoop
  • I'm a llama!
« Reply #7 on: February 27, 2006 - 08:18:28 PM »
I got the sway bar from the Roadrunner are the lower contol arms a direct bolt on?  Also is there any difference in k members (other than part number) between a six cylinder and a big block k member?
« Last Edit: February 27, 2006 - 08:26:14 PM by jshoop »
« Reply #8 on: February 27, 2006 - 11:31:31 PM »
LCA bolt right on , the /6 K is totally different from the V8 K frame
Offline jshoop
  • I'm a llama!
« Reply #9 on: February 28, 2006 - 06:56:00 PM »
The reason I'm asking is because my Challenger was a 6 cylinder car, but someone has put a 400 in it.  I don't know if they changed to a V8 one or rigged somthing up.  What is different exactly about them?
« Reply #10 on: February 28, 2006 - 08:15:02 PM »
the mounts are totally different , the reight mount is low & the left is higher , V8 s are even
Offline jshoop
  • I'm a llama!
« Reply #11 on: March 01, 2006 - 07:03:56 PM »
I'll have to look at mine and see what I have or if the've got in rigged up.  It wouldn't be surprising on this car! :working:
