Author Topic: Procharger?  (Read 1751 times)
Offline ReturnofCuda
Procharger?
« on: February 09, 2006 - 12:02:57 PM »
Is anyone running a procharger on a small block? Drivability? Horsepower? What work do you have done to the motor? I'm thinking about putting one my 340. :working:
Doug
1973 Cuda 340, TF727, 8 3/4 3.55 posi
Offline pink panther
Re: Procharger?
« Reply #1 on: February 09, 2006 - 07:57:21 PM »
like to see how that works out.
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Procharger?
« Reply #2 on: February 09, 2006 - 09:04:13 PM »
I don't have one on my '72 340 but tinkered with the idea since it's already at 8.5:1 compression (enigine still stock, never taken apart.).  Here's a reply I got back from Bob at http://www.thesuperchargerstore.com/
Hope this gives you a little info.  The reply was a couple of years ago so the prices/info may be a little different now.
I do not believe a car with an 8/71 build date is a left over 71 model, so your compression ratio should be just fine. The engine has a lot of miles but if it is in good condition the supercharger will not adversely affect the longevity. The Thermoquad carburetor is a problem though. You will need to use a Holley with mechanical secondaries. The boost is changed by changing the driven pulley on the supercharger. You should have no problem achieving 400 horsepower. The price for a P-1SC for your small block is $2696.00. Power steering adds $400.00 for a new Saginaw power steering pump with remote reservoir and new hoses. Power brakes adds $50.00 for a check valve for the power brake vacuum hose. Thank you for your interest in our product.    Bob
Offline Follicly Challenged
Re: Procharger?
« Reply #3 on: February 10, 2006 - 12:21:10 AM »
Stock CAST pistons aren't a great idea with boost. If you're rebuilding, best pop for a set of FORGED slugs.
Should be a neat deal !
nivvy
Re: Procharger?
« Reply #4 on: February 10, 2006 - 12:31:41 AM »
I am going to get one eventually...but I need a minimum of the f3 which will support up to 1050hp...cost will be $6 grand because i need the water injection kit...and also switch to a cam with a wide centerline...I need the f3 minimum due to my motor being a 500 stroker...
8 Pack
Re: Procharger?
« Reply #5 on: February 10, 2006 - 07:32:56 AM »
I already have forged pistons, was thinking of dropping compression to 8:1 instead of 9.5:1 which I have now. Also was going to put a set of Indy 360-2 heads on. The blower I'm looking at is the P-1SC or the D-1SC, and an intercooler. Was going to run @ 10 psi to 14 psi of boost. It will be close to $4000 for the blower set up and $1200 for the heads.Looking to get between 600 hp and 700 hp and still be tame enough to drive on the street. Was also going to contact engle cams for a recommendation on the cam, it will probably have a 112 to 114 degree centerline. A close friend of mine runs the Stahl header fab shop and he's going to custom build a set of headers for me for free, he owes me one for rewiring his basement. A set of those headers is worth about $3000 according to him. :money: Free is nice! :bigsmile:
Doug
Offline haplo
  • no i am not
Re: Procharger?
« Reply #6 on: February 10, 2006 - 06:17:51 PM »
 I ran a procharger on a 1995 z28 (sorry) and it ran great.. had about 12 p boost .intercool mounted in the front .put out 485 hp on rear tires.  Had no problems at all except no traction.
Re: Procharger?
« Reply #7 on: February 11, 2006 - 06:17:38 PM »
What mods did you have to the motor?
Doug
Offline GreenFish
Re: Procharger?
« Reply #8 on: February 14, 2006 - 08:14:48 AM »
Check out the latest issue of Mopar Muscle Magazine, they did an engine build up the an ATI procharger on it. Made some rediculus HP.
