Author Topic: trim removal help  (Read 1144 times)
Offline 71fish
  • Bless you..
    • Ken's 71fish
trim removal help
« on: February 09, 2006 - 06:09:20 PM »
I've never really have taken off the window & door chrome trim. What is the best procedure? Do I need a special too. The window trim seems especially tight.. not sure if it's siliconed.. hope not.
Pls give me any tips, advice or procedures..
71fish
71fish - Nobody better than an E-BODY!!
Offline 70 RT Convt
Re: trim removal help
« Reply #1 on: February 09, 2006 - 06:58:39 PM »
There is a tool for removing moldings, I found it at yearone it's ( T82 Reveal molding removal tool) it says for GM but i think it would work mopar's too :dunno:Look under body parts :cheers:
1970 R/T Challenger Convertible
2011 R/T Classic
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #2 on: February 10, 2006 - 05:44:43 AM »
Thanks, I'll check it out
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #3 on: February 10, 2006 - 11:30:40 AM »
We got our trim tool at NAPA for about $8.  They are a bugger to get out.
Offline Street_Challenged73
« Reply #4 on: February 10, 2006 - 06:10:13 PM »
71Fish, I had great results by getting the lower windshield trim (where the wiper blades sit above) unscrewed, then just slowly work your way up from each side using mostly your hands and maybe some slight prying from the inside pushing out with a stiff plastic wedge (plastic putty knife or something along those lines).  There will be spots where the windshield adhesive adhered to the moulding, so you'll need a razor blade to help you out.  As for the rear, it's a little tougher to get off, since you don't have any screwed-in trim pieces to remove and help speed up the process.  Pretty much just use that non-marring pry tool of some sort and a lot of handwork and you shouldn't have any problems getting them out.  As for the driprail mouldings, all you need is to remove the weatherstripping and that'll give you access to the screws that hold the moulding in place. :cheers:
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #5 on: February 10, 2006 - 07:50:48 PM »
thanks folks.. started block sanding the shaker hood & fenders already.. I'll just take it to a shop to paint. Blocking the old paint should make her look pretty straight. I plan on driving it to carslile this year..
-71fish
Offline common 27
« Reply #6 on: February 11, 2006 - 09:11:19 AM »
Do not pry it off!! the clips spring up and you need a tool to hold it down while you pull the trim up a little at a time .Work your way up with the tool to each clip..With the tool it is easy and won't damage the trim.
1970  Challenger Convertible   1968 Satellite Convertible
