Author Topic: 1970 Challenger Remote mirror control unit  (Read 6147 times)
Offline 70RTdroptop
  • 1970 Challenger R/T 440-SixPack
« on: February 09, 2006 - 09:47:08 PM »
When I got my Challenger in 2004, the driver side mirror wiggled like crazy - no wonder, I find it's a remote control mirror which wasn't hooked up. The guys I bought the car from had installed new door panels and conveniently forgot to drill a hole in the door panel and hook up the remote control mirror. Well, I want to get the remote mirror control back in my life, I've got the threaded chrome bezel for the control, but how do I keep the unit from falling back out of the hole? Is there a threaded nut or c-clip or something on the backside of the door panel to hold everything in place? And if so, who might carry such an item? Thanks for any help!
1970 Dodge Challenger R/T 440-6 convertible
1966 Ford Mustang convertible  - numbers matching (wife's car )
Alaskan_TA
Re: 1970 Challenger Remote mirror control unit
« Reply #1 on: February 09, 2006 - 10:45:18 PM »
For 1970 there was a stamped steel retainer, it looks like the one in the photo. Later models used a thin stamped nut. I have an extra nut, if you want it PM me with your mailing address and I will send it to you.
T/Ake care,
Barry
Offline Killer_Mopar
« Reply #2 on: February 09, 2006 - 10:53:45 PM »
Hmm not to hi-jack your thread or anything, I just thought about something when you posted this. I dont think Chrysler did but I will ask anyway. Did chrysler make a non-remote sport mirror?? If not, how would one go about installing a sport mirror in place of a standard mirror without a remote??? Reason being is because I really dont like/want the remote mirror and I would hate to cut up my door factory SE door panel.
Alaskan_TA
« Reply #3 on: February 09, 2006 - 11:33:21 PM »
 The driver's side racing mirrors were all remote.
An SE with the std. mirror has to be pretty unusual!
Barry
« Reply #4 on: February 09, 2006 - 11:38:36 PM »
Thought they all are remote, thankyou for confirming it. Im guessing that nobody else has ever tried doing what I plan on doing, maybe I can find a junk passenger mirror and adapt the internals to the drivers mirror.
Barry
That is the main reason why I dont want to cut up my door panels......
« Reply #5 on: February 09, 2006 - 11:43:37 PM »
mine was an SE with std mirror also
Alaskan_TA
« Reply #6 on: February 09, 2006 - 11:56:13 PM »
I want to head the other direction and convert my passenger side racing mirror to remote.  :bigsmile:
Barry
Offline 70RTdroptop
« Reply #7 on: February 11, 2006 - 12:16:29 PM »
Thanks for the help, Alaskan_TA! I could definitely use that retainer you've got! I'll pm you with mailing info.
Offline AllGreen70RT
« Reply #8 on: February 14, 2006 - 07:46:12 PM »
I am also missing the same retainer. Does anyone know if it is being reproduced?
Offline 70RTdroptop
« Reply #9 on: February 18, 2006 - 11:32:28 AM »
Hey, Alaskan_TA, just wanted to let you know I received that thin threaded nut to hold in my remote control mirror unit. That'll keep the unit from falling out of the door panel for sure! Thanks again for the help!:worshippy
Offline FY1 RT SE
« Reply #10 on: February 18, 2006 - 05:00:43 PM »
You will also need this bracket or something similar to keep the cables from binding with the window.
Offline 70RTdroptop
« Reply #11 on: February 18, 2006 - 08:31:28 PM »
Man, I didn't even think about that! Any idea where I can get one? Also, where would that bracket mount ? Any help greatly appreciated!
Offline 71340RT
« Reply #12 on: February 18, 2006 - 10:51:50 PM »
It mounts on the inside upper front of the of the door. The picture is not very good nut goes on the inside like this.
« Last Edit: February 19, 2006 - 11:21:21 AM by 4cruzin »
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline 70RTdroptop
« Reply #13 on: February 19, 2006 - 08:46:09 PM »
Never mind! Took off the driver door panel, peeked inside the door, found that cable routing bracket already installed. Thanks for the tip, though!
« Reply #14 on: February 19, 2006 - 08:58:02 PM »
Does anyone know if the stamped steel retainer for the mirror control is being reproduced?
