Author Topic: vin  (Read 2332 times)
Offline jasonmtcsn
vin
« on: February 12, 2006 - 05:13:00 PM »
Does anyone know where the vin is on a 72 318 block? :chatting:
Offline Tropicalcats
  • Don't Ever, Ever Give Up
SOLD
Alaskan_TA
Re: vin
« Reply #2 on: February 12, 2006 - 09:03:02 PM »
Look on the passenger side of the block. Right above the oil pan rail towards the front of the block there is a raised pad about three inches long. The last 8 digits of the VIN should be there.
T-cat, just so you know, the thread on Dave's board that you linked to predated his site crash, so the photos are gone.
T/Ake care,
Barry
Offline jasonmtcsn
Re: vin
« Reply #3 on: February 12, 2006 - 09:15:11 PM »
Thank you for the replies . :cheers:
Is the oil pan rail where the pan bolts to bottom of motor?
« Last Edit: February 12, 2006 - 09:17:19 PM by jasonmtcsn »
Alaskan_TA
Re: vin
« Reply #4 on: February 12, 2006 - 09:48:50 PM »
Yes it is. Here is a photo that may help, the VIN pad is circled in yellow.
T/Ake care,
Barry
Offline jasonmtcsn
Re: vin
« Reply #5 on: February 12, 2006 - 10:18:48 PM »
Cool thank you,
Is it stamped on a separate pad or on the block itself?
Someone painted the block, and I'm not seeing it anywhere.
I was wondering if it could have been removed, or if it was just painted over.
Thank you for your help Alaska!!!
Alaskan_TA
Re: vin
« Reply #6 on: February 12, 2006 - 11:08:24 PM »
The pad is part of the block, you may have to scrape some paint off to read the numbers.
Best of luck,
Barry
Re: vin
« Reply #7 on: February 13, 2006 - 02:13:23 PM »
Quote
author=
T/Ake care,
Barry
Thanks Barry
I'll update
« Last Edit: February 13, 2006 - 02:42:16 PM by 4cruzin »
SOLD
Offline jasonmtcsn
Re: vin
« Reply #8 on: February 13, 2006 - 07:11:01 PM »
There is no vin there, I have removed all paint. Is there any chance it wasn't stamped? The metal is smooth, but no vin.
Thank you!!!
Alaskan_TA
Re: vin
« Reply #9 on: February 13, 2006 - 08:42:02 PM »
It may be a warranty replacement block then? Look on the drivers side for an aluminum tag riveted to the block.
T/Ake care,
Barry
Offline jasonmtcsn
Re: vin
« Reply #10 on: February 13, 2006 - 09:03:54 PM »
 :sadwavey:
I combed the block over, no tags on either side.
On the passanger side of the block, that vin area is there, but it is blank of #'s.
The tranny matches my vin#, and the block is casted 72 like the car.
Should I trash it and get a 440 block?
Thanks Alaska.
Offline Stacked440
Re: vin
« Reply #11 on: February 23, 2006 - 08:17:12 AM »
Its probably a warranty block meaning someone bought it new and something went wrong with the engine and it was replaced under warranty.  All warranty blocks don't have vins just casting dates.  And as far as trashing it for a 440 goes, it all depends what you want out of the car.  With an edelbrock build-up you can make a 318 pushing 425 hp easy.  your choice :thumbsup:
-Kyle-
