Author Topic: sound system options?  (Read 15356 times)
Offline hemi71
Re: sound system options?
« Reply #30 on: February 17, 2006 - 03:31:39 PM »
You have a point about hemi music...the 71 i just sold with 3 inch TTI exhaust and 40 series flowmasters made it impossible to hear the tunes when drivin.
My 70 has TTI 3 inch with headers, but with the mufflers on it, is fairly quiet.
[attachment deleted by admin]
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #31 on: February 03, 2007 - 12:03:12 AM »
Now that "I-pod" type technology has advanced another year, what's the latest, discreet,
Hot set-up that I can put into my 1970.
Has the stock am/fm with a fader now... oooooo :grinyes:!
Rather not remove it. :dunno:
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Offline crcarch
  • Happiness is having the time and the money!
  • "No, it's not a Charger!"
    • A little history and restoration pics on Cardomain
« Reply #32 on: February 03, 2007 - 07:19:03 AM »
More and more head units come with an infrared remote.  They make a wired infrared receiver (used in media rooms where the equipment is hidden) that's little more than a black tic-tac.  You could incorporate it somewhere on the dash, and simply run the wire to the trunk where you can have a box to hold the equipment.  That would allow you to control your equipment via the remote without actually being able to touch it and if you also have an Ipod, you won't need to access it to change CD's.
Put 3 1/2" midrange/tweeters into your dash corners (or together on a plate if you only have the center 4x10 opening), use the 6x9 factory openings in the package tray and place a small box firing towards the rear seat.  Better yet, port it through the defroster opening.  This can leave it absolutely stock looking on the inside and still provide modern tunes.
00/===\00 73 Challenger 440-4V/AT  8/--+--\8 09 Ram 1500  0o\==/o0 05 Crossfire Roadster OO(#####SRT)OO 10 Challenger
« Reply #33 on: February 03, 2007 - 07:34:33 AM »
I've been watching for the newer technology to find it's way into the auto market & things are looking pretty good. Here is a low priced highly featured head unit, $144.00. See the USB! No more changers needed IMHO.
USB Encode - Decode Interface: Play MP3 Files From and Record Radio or CDs To USB Devices!
In-Dash CD / MP3 / USB Receiver
Motorized Slide-Down Detachable Face
PLL Synthesizer Stereo Tuner
XM Satellite Radio controls (tuner, antenna, and subscription required and not included with purchase -- Term XMD1000 and Audiobahn AXMCABLE required)
iPod Direct (Audiobahn iPod Direct Unit Required, Not Included)
USB Port on Faceplate
Automatic Memory Storing
Preset EQ
Electronic Shockproof (ESP) Function
CD Changer Control
RCA Outputs: 2 Pair (Front, Rear) + Mono Sub
RCA Inputs: 2 Pair
Wireless Remote Included
CD-R/RW Compatible
1-year Sonic Electronix warranty
  • HvacMan
« Reply #34 on: February 03, 2007 - 08:11:41 PM »
More and more head units come with an infrared remote.   Put 3 1/2" midrange/tweeters into your dash corners (or together on a plate if you only have the center 4x10 opening),
Thanks , that sounds good.
One question: I have the single speaker dash. Do I have to remove it to get those speakers you mentioned installed?
Also..thanks bullit I'll research that sonic unit. Have you used it?
Eric
Bay Area California
« Reply #35 on: February 03, 2007 - 08:32:14 PM »
No, I'll be waiting till the car is closer to being finished. That is just one of many I have seen, some are using flash memory cards rather than USB.
Offline Andrew
« Reply #36 on: February 03, 2007 - 09:13:42 PM »
I have also seen head units as well as alot of other devices (MP3 players, home stereos, dvd players etc.) with SD/MMC card slots in so you can simply store your music on a card, and as well as not having to carry a clunky ipod around (or have it sliding across the dash and out the window on tight corners) you can play your music on multiple devices without having to purchase all kinds of weird ipod accessories to get them to connect.
  • HvacMan
« Reply #37 on: February 03, 2007 - 11:31:12 PM »
anyone have a good link to a www. site for this sort of equip.?
Eric
Bay Area California
Offline crcarch
« Reply #38 on: February 04, 2007 - 07:46:43 AM »
I have the single speaker dash. Do I have to remove it to get those speakers you mentioned installed?....
You simply unscrew the grill and replace the speaker with a plate to hold the speakers.  You can get some galv. flashing from Home Depot or Lowe's and cut it to size, then cut two holes for the speakers to mount to the plate.  Paint the plate black to keep it from showing. Make sure to put bass blockers on the speakers if you're head unit doesn't have a crossover.  You don't want to blow them.  I'd suggest keeping them above 400 HZ.
www.crutchfield.com  Great resource and good tech support but you can usually buy cheaper elsewhere.
« Reply #39 on: February 04, 2007 - 07:57:09 AM »
I have not done business with them & they seem to carry the lesser known brands but the pricing seems good http://www.sonicelectronix.com/index.php
Offline Wang
  • "just hangin' out"
    • valleyautoworks.net
« Reply #40 on: February 04, 2007 - 09:06:34 AM »
there is a radio at Best Buy,, I cant remember the manufacturer(sorry), but It allows you to plug in a usb cable or a Jump drive. I am going to look at this thing again, and will
let you all know my thoughts after a closer look. I may even buy one.
Hurry,, Duane the tub,,I'm Dwouning....
Offline Carlwalski
« Reply #41 on: February 04, 2007 - 03:29:33 PM »
Sound system options: 340ci, 383ci, 440ci, Hemi.....  :naughty:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
  • HvacMan
« Reply #42 on: February 04, 2007 - 09:25:21 PM »
 :iagree: I agree ...my 440-6 is sounding cool rowing thru the 4-gear.
But, at some point some crankin' tunes would be cool.
I ain't THAT old yet :ylsuper:
Just trying to figure out how to do it with the least modifications to the car/looks.
Thanks CRCARCH, WANG, and BULLITT. I appreciate the input.
Oh, and Andrew I know whatcha mean about sliding. My cell phone always ends up by the passenger door.  ;)
Eric
Bay Area California
