Author Topic: tachometer hookup help  (Read 2823 times)
Offline 70challengerrt
« on: February 16, 2006 - 03:31:11 PM »
I need help! I was hooking up my tack today and I noticed that the wires were cut and that was why it didn't work. There is a dark blue wire that according to the schematic goes to the tack and a wire goes from the tach to the negitive side of the coil.The original harness had this wire pulled out so I just ran one. When I did this at idle the tach works but reads about 6 grand. It is the 8000 rpm gauge in the original 70 rally dash.  Any suggestions. :1zhelp:
Re: tachometer hookup help
« Reply #1 on: February 16, 2006 - 03:42:43 PM »
That's a toughie. The blue wire is your power. Do you still have a Mopar ignition system? I'm just wondering if maybe it has been converted to a Mallory, or MSD, or such.
Edit: There is always the chance that the tach. just needs taken out and calibrated, as these were cheaply made, but maaan that is FAR off, if that's the case.
« Last Edit: February 16, 2006 - 03:45:03 PM by MEKrunner »
« Reply #2 on: February 16, 2006 - 04:00:36 PM »
Its stock mopar ignition but it was upgaded to eletronic. I used the stock black box not the orange box.
« Reply #3 on: February 17, 2006 - 03:26:13 AM »
OK then. I wasn't sure if a non-Mopar ignition would make it act incorrectly or not, but I just wanted to ask anyway. My only guess here is the tach itself needs some attention. Something inside isn't working right.
« Reply #4 on: February 19, 2006 - 10:03:23 PM »
www.RT-Eng.com has a fix for Tachs that read incorrectly
« Reply #5 on: March 10, 2006 - 07:58:56 PM »
I was told that mopars used a resistor wire which had a total of 680 ohms so I used a 680 ohm resistor in a primary wire and the tach was close, but the needle moved slow. Does anyone ever heard of this, is this right?
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #6 on: March 11, 2006 - 09:02:46 AM »
never heard of that one- if the tach needed a 680 ohm resistor- they would of put one in the tach itself as it was cheaper that way instead of using a expensive extra wire for a specific purpose- ie- not worth the trouble!!
tach needs some work to it.
had the same problem years ago- found that by using the old cap on the old points dist. on the neg side of the coil to ground helped to take the bounce out of the tach!
Offline hemi71
« Reply #7 on: March 14, 2006 - 11:32:07 AM »
Just a FYI....if you are running a MSD ignition, the factory tach will not work corretly. MSD sells a "tach adaptor" that will make everything work OK.
[attachment deleted by admin]
« Reply #8 on: March 14, 2006 - 01:25:42 PM »
It looks stock including the coil, but it is out of a 75 chrsyler newport.
