Author Topic: Correct master cylinder?  (Read 947 times)
Offline Ozdrums
« on: February 16, 2006 - 06:52:49 PM »
Am trying to figure out which master cylinder is correct for a 70 Challenger RT/SE 383 with power disc brakes with Hemi suspension. This was a one owner car but has had a power brake booster replaced during it life. The master on the car resembles the hemi unit in that it has a larger capacity front brake reservoir (rear section) than the rear brake ( front section), and the cover is rectangular in shape. The master I was sent to replace it is much smaller with equal capacity storage for front & rear. I thought when I received it that it was probably for all wheel drum type brakes as the fluid reservoirs were the same size. Generally disc/drum combos have different capacities. They both have the correct 4 bolt mount to the booster.
Can anyone give any info and/or pics of what is correct?
Sorry to be so long winded but wanted to give as much info as possible.
Offline rm23j8g
Re: Correct master cylinder?
« Reply #1 on: February 16, 2006 - 07:45:49 PM »
My car is that very thing....
I'll try to shoot a pic for you in the next day or so and post it here...
Guy
Alaskan_TA
« Reply #2 on: February 17, 2006 - 11:30:19 AM »
Go to this link;
http://www.challengertaregistry.com/brakes.html
The article was written with AARs and T/As in mind, but I am pretty sure that your car would have the same brake components.
Best of luck,
Barry
Offline hemi71
« Reply #3 on: February 17, 2006 - 09:24:55 PM »
The master cylinder you need is the one with the larger size reservoir for the discs. You are correct in that the equal size units are for 4-wheel drum brake cars. using a drum brake master on a disc brake acr is asking for trouble...insufficient reservoir size will cause the master to run dry trying to move enough fluid to apply those discs.
My cuda came with the incorrect drum master (top pic)
Correct master is shown on bottom pic
[attachment deleted by admin]
Offline FY1 RT SE
« Reply #4 on: February 18, 2006 - 12:14:50 AM »
No such thing as an equal sized reservoir in 1970.
Drum Brake top, disc brake except Hemi middle, Hemi bottom.
Offline Ozdrums
« Reply #5 on: February 18, 2006 - 06:29:57 AM »
Thanks for all the great info and pictures. I thought that the one on the car was the original style but second guessed everything when I received the replacement.
Thanks again
Greg
