Author Topic: keisler 5 speed????  (Read 3469 times)
Offline BIG MIKE
keisler 5 speed????
« on: February 06, 2003 - 12:59:37 AM »
do you know somebody that tried these trans. if so did they have problems.....i have been thinking on the conversion
Offline rcerex
  • 70 Cuda 520" project
Re:keisler 5 speed????
« Reply #1 on: March 08, 2003 - 01:40:40 AM »
sorry, never talked to anyone in person. It seems like the easiest(but one of the most expensive) of the various swaps out there. Then Nash has to be cut in to fit,  the 6 speed would need an adapter and a hydralic clutch as well as extensive cutting.
Ducati 748S corner carving fun!!!
Offline jterp
  • fast
« Reply #2 on: June 06, 2003 - 05:30:50 PM »
I put one in my cuda last winter. (I have a 70 convertible with a 360 crate motor-- had a 727 before hand )  The conversion was not as easy as they say... but with some know how you can get it in and it works very well! Quick quarter miles and cruising at 75 mph at 2000 RPM-- great gas mileage. I've beat the hell out of it drag racing a few times over the past year and its held up very well. The only complaint that i have is that it doesnt shift as fast as i would like under load-- unlike an old 4 speed, it has to reload in neautral, which makes the shift an out of gear-in to gear shift instead of one smooth motion. I can go in to more detail if you want .. let me know spec. questions....
70 cuda convertible - 360 crate motor, keisler 5 speed, 3.55 posi, tti headers/3 inch pipes
Offline Carlwalski
« Reply #3 on: October 01, 2003 - 06:58:56 AM »
Also know a few guys who have installed these trans and have had no problems at all either in the install or  driving.  :)
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
mopar340
« Reply #4 on: October 02, 2003 - 07:54:39 AM »
A freind of mine has the 5-spd behind a hemi. No problems with the trans that I know of. He has had some problems with their dual friction clutch and is working those problems out. I have the trans new in the box just waiting to get my car back from the body shop. Looks fairly straight foward as far as installation.
Offline BP23N
« Reply #5 on: November 06, 2003 - 10:49:35 PM »
I haven't had any problem shifting mine fast! The internal rail shifting mechanism shifts alot smoother and more precise than the cluncky linkages on the old style!
Offline GreenFish
« Reply #6 on: November 10, 2003 - 09:37:05 AM »
saving my pennies for mine
Offline kowalski
  • Challenger=SCCA Trans Am Homologation Special
« Reply #7 on: January 01, 2004 - 12:43:19 PM »
Is the kit as complete as they say it is?  What is the cost?
1970 318 bored .060 over edelbrock performer intake ported and polished 360 J heads 2.02 intake 1.60 exhaust double springs carter hi cap fuel pump edelbrock victor series water pump MSD 6AL flotech headers
Offline SageCuda
  • 71 Cuda - Being restored.. slowly.
« Reply #8 on: January 05, 2004 - 01:28:25 PM »
They look pretty complete, but are pretty spendy.  Seems like most of the folks who have one are pretty happy with it.
You can check the E-body kits out here:
http://www.keislerauto.com/mopar/transmissions/e-body_70-74.asp
-Sage
Offline rtgambit
  • Member since March 31, 2003
« Reply #9 on: January 06, 2004 - 12:06:52 AM »
Just wanted to throw my 2 cents in here...
I'm also on the MML and there's a couple of gents in California (Jeff and Jeff) that went the Keisler 5 speed route.
They've had nothing but trouble and headaches.
Both cars are 1970 small blocks as well, so that might have made a difference in their setup.
Matthew
1967 Dodge Dart GT
1971 Dodge Challenger R/T
2014 Ram 1500
Offline 1973challenger360
« Reply #10 on: January 09, 2004 - 12:53:32 AM »
has anyone used a gear venders behind a 833 ?
