Diamonds in the Ruff
Author Topic: Diamonds in the Ruff  (Read 6418 times)
Offline 440six
  • I Luv E-Bodies
Re:Diamonds in the Ruff
« Reply #15 on: April 13, 2003 - 06:50:51 PM »
I read some where that they came out with a 440 later in that year, it did 0 - 60 in something like 5.5 sec.  and had a 14 sec quarter mile. pretty inpressive. Wasn't there a 340 motor also optioned on the cuda model in 69?
lemonboy69
« Reply #16 on: April 13, 2003 - 08:40:42 PM »
From what I have read and seen, you could also get a 340 in the Formula S package... but it wasn't as chosen as the 383 or 440 for obvious reasons... although that 340 is one killer engine!!
LB
Offline 1973challenger360
« Reply #17 on: August 15, 2003 - 09:41:11 PM »
The formula S came out in 65 with a 235hp 273 4bbl same for 66, 67 came with 273 4bbl or 383, 68 came standard with 340, 383 option, 69 340 standard, 383 option 440 limited option.
The 273 has a tiny cam  235hp cam  .415/.425  248/248
I wonder how much power a 273 would make with 340 heads, intake, cam, carb and exhaust ???????
Looking at the standard features of the 273 64-67 Ma Mopars best parts went into these babys
Forged cranks went in
64-67       273's
67            318's
68-71       340's
273 pistons   lightest small block
64-67        2bbl   530grams
65-67        4bbl   569grams
68-69                 547grams
360                     584grams
318                     592-594grams
340                     720grams     :(
Adjustable rockers came on
64-67        273's
70             340 T/A motors
Forged vibration dampers
64-69       273's
67            318's
68-72       340's    some 72's were not
Mech Cams
64-67       273's
no             340's
Another thought    t/a motors cam
hyd.    .430/.444    268/276
same as 70 340 non t/a cam, but not the largest small block cam in 68 340 manual cars had a  .444/.453   276/284
Some in theory  the 273 and 340 have the same parts   rods, crank  travel, journal size, dampers, rockers.  Adjustable not roller tips but hey you could run a Mech. Cam.....
If 1 had a junk 340 (bad crank or 72 or 73)(72-73 do not have forged cranks, there not junk) a 273 donor engine would supply a lot of good parts.....  273's are cheap ;D
Offline oldvamoparfan
  • MOPAR; The only way to go!!!!!!!
« Reply #18 on: September 25, 2003 - 10:31:12 PM »
To LB,  For disc brakes for the A body Cuda, all you need is a 73 Up Dart Or Valiant V8 car.  Use the upper control arm, entire spindle/hub assembly, caliper & hose.  The only disadvantage is you will also pick up the 4 1/2 in bolt circle for the wheels.  If you do this, you can use the rear axle from the same later A body & that way you also get 10" rear drums.  You might also get the 8.25 gear too.  The 69 probably has a 7.25 & 9' drums.  I did this same swap on my 65 Cuda. The rear was from a 74 Valiant & the Discs from a 73 Dart.  The reason you use the upper control arms is the disc brake cars have a different upper ball joint.  If you didnt already have the small bolt pattern rallies, then there is no disadvantage.  I have 72 Cuda 14x6 rallies on my 65.  Ovmf
'72 Challenger 360,  '05 Dakota,   04 Town & Country,   '82 Yamaha 650 Maxim
Offline Moparmatt
  • Mopar or No Car - Member Since 10/09/03
« Reply #19 on: January 12, 2004 - 03:36:06 PM »
Called Heavy Metal Auto Wreckers, the yard in this post. They said that they no longer had the 71 cuda, however they did have some other e-body parts cars.
Offline 440six
  • I Luv E-Bodies
« Reply #20 on: January 16, 2004 - 12:32:57 PM »
Someone came a long last summer and bought the shell. There has been several Challengers going as well. I'm glad I got my parts when I did.
If your into 71 -74 Chargers and A-bodies, he has several complete cars. Also some good parts for late 60's B-body.
Offline JS27N0B
  • Member since Jan 28th 2003.
Re: Diamonds in the Ruff
« Reply #21 on: June 19, 2004 - 10:39:26 PM »
LB,
the Cuda was a seperate model in 69 seperate from formula S cars. You can tell the Cuda models by the blacked out rockers with Cud callout on the fenders and the dual hood scoops at the back of the hood. These were one year only cars. Probably less than 400 made.
2013 Tige' RZR 343hp
Offline TreeFrog
    • TreeFrog
« Reply #22 on: June 24, 2004 - 02:22:40 PM »
any chance of a 72-74 Passenger fender and or bumper fillers for a Challenger?
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline Moparmatt
« Reply #23 on: June 24, 2004 - 03:48:19 PM »
They might. Give them a call and see what they can turn up.
