Author Topic: ignition switch removal  (Read 5759 times)
Offline mikeinsjc
« on: February 19, 2006 - 08:07:47 PM »
I am rebuilding the steering column on my challenger. How do you remove the ignition switch? I have popped off the chrome bezel. How is the switch (the part the key goes in, not the part with the wiring harness) held in the housing? Does it press out to the inside or to the outside of the collar? Is there anything else holding it into the collar? Thanks.
70 cuda
70 challenger
69 6 pack rr
Offline 4Cruizn
  • HEMI FISH
Re: ignition switch removal
« Reply #1 on: February 19, 2006 - 09:44:01 PM »
Chryco can probably explain it better than me but there in a small button you have to hold in about the size of the head of a finish nail on the side of the lock assembly to remove it from the column.  Hold it in and pull the lock cylinder out.  Hope this helps!   :cheers:
« Reply #2 on: February 19, 2006 - 11:04:59 PM »
there are 2 Phillips screws that hold down the plate around the lock tab onder the lock plate that rotates with the column , remove the 2 phillips screws & move the plate inward toward the steering colun shaft , under this plate is a small pin that needs to be depressed to remove the lock
Offline mikeinsjc
« Reply #3 on: February 19, 2006 - 11:56:49 PM »
Got it out- thanks guys- could never have figured that out on my own.
70 cuda
70 challenger
69 6 pack rr
« Reply #4 on: February 20, 2006 - 12:16:07 AM »
 :thumbsup:
Offline David_Lee
« Reply #5 on: September 05, 2011 - 04:01:18 AM »
I know this is real old post but I am having one hell of a time trying to remove the ignition lock out of my challenger. does any one have a pic of the the two screws that have to be removed so I can get  my new ignition in
67 Cuda Notchback
68 Valiant 170
69 Coronet RT 440
70 340 Cuda Auto
70 383 Challenger Western Sport Special
71 Dodge Demon 340
73 Duster 340 F/SA Stock Eliminator
Offline Katfish
  • 70 Challenger
« Reply #6 on: September 05, 2011 - 10:24:45 AM »
Offline David_Lee
« Reply #7 on: September 05, 2011 - 04:12:41 PM »
Finally got it. Thanks much for the help
« Last Edit: September 05, 2011 - 09:35:58 PM by David_Lee »
67 Cuda Notchback
68 Valiant 170
69 Coronet RT 440
70 340 Cuda Auto
71 Dodge Demon 340
