Author Topic: Difference between "x" and "j" heads?  (Read 15032 times)
Offline Whitehatspecial
« on: February 19, 2006 - 08:56:29 PM »
Building a performance 340 to replace the 318 in my car. I'm now trying to decide what heads to use. I've got a pair of 1972 J heads with 1.88 intake valves that need to be done over. What is the difference between a set of "J" heads with 2.02 valves and "x" heads with the same sized valves.
Someone told me that J heads (with 1.88 valves ) are smog heads and won't flow the same as X heads even if 2.02 valves are installed.
Offline Rob C
Re: Difference between "x" and "j" heads?
« Reply #1 on: February 19, 2006 - 10:44:14 PM »
Same head, same casting number, smaller valve, bad freind poor info.
'73 Cuda, 360, 4psd & 4.10's
'79 Dodge Magnum, 360, 727, 9-1/4 W/3.55's
« Reply #2 on: February 19, 2006 - 11:44:07 PM »
I would use the 87-92 308 casting a pick up 40 HP over the X or J heads
« Reply #3 on: February 20, 2006 - 07:07:40 AM »
What kind of aluminum intake would you use with 308 magnum heads?
Offline moparnut
    • My Photo's
« Reply #4 on: February 20, 2006 - 09:12:51 AM »
Chryco,what did the 308's come on?How to identify?Is there a 308 casting number on them?thanks
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
« Reply #5 on: February 20, 2006 - 09:58:56 AM »
the 308 heads are Pre Magnum & all LA intakes fit from 66-92
 308 heads come on 87-92 Dodge trucks with the 360 engine & yes there is a 308 casting # under the intake runner on the heads
 I port them to maximize the flow , you can have 2.08 intake valves installed But the heads work well with the stock size intakes also
Offline moparnut
    • My Photo's
« Reply #6 on: February 20, 2006 - 10:25:51 AM »
thanks Chryco,so the 308's with stock valves will outperform a J head with 202's?
« Reply #7 on: February 20, 2006 - 10:31:13 AM »
I dynoed a 340 last year , we removed X heads & bolted on ported 308 heads , nothing else was changed including the timing , the rear wheel HP was up 41 HP
Offline moparnut
    • My Photo's
« Reply #8 on: February 20, 2006 - 10:43:31 AM »
thanks for the info,do you think the porting is what gave you the extra HP or the heads.I would be curious to see if there is any HP difference between stock 308's and stock J heads with 202's
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #9 on: February 20, 2006 - 10:52:21 AM »
What does a  "U" or "O" head belong on with the 2.02 valves? Was told TA heads. I just bought a rebuilt 340 with "U" heads and the LD340 intake.
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline Follicly Challenged
« Reply #10 on: February 20, 2006 - 11:33:31 AM »
Different "short turn" on the intake side of the "X" head from the "J", but less swirl, Don't matter anyways, I vote the "308" deal these days.
FC out.
Offline moparnut
    • My Photo's
« Reply #11 on: February 20, 2006 - 01:53:24 PM »
Nope TA heads are W2 heads,good luck finding them
Offline moparnut
    • My Photo's
« Reply #12 on: February 20, 2006 - 02:00:52 PM »
And they have adjustable rockers
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #13 on: February 20, 2006 - 03:27:18 PM »
Not sure. I'll pull a valve cover and check it out.
« Reply #14 on: February 20, 2006 - 05:28:00 PM »
With all due respect to ChrycoPsycho, I would like this engine to look vintage since the car is really a time capsule itself. While the 308 heads may add a bit more hp, I'm having a mental problem bolting on 80's heads to a 60's motor and setup.
I'm sure the 308 swirl heads do add punch (and certainly a lot cheaper than doing the old x heads over) and I'd like to hear more about what other mods (rockers, cam, etc.) are necessary before jumping an board.
Do 308 heads need roller's?
