Author Topic: searching a cam  (Read 1782 times)
Offline Dosz
searching a cam
« on: February 20, 2006 - 09:02:02 AM »
I have e 318 stock and I'm searching for a cam replacement.  I was thinking of the edelbrock 2177 cam
Is this a good Idea of are there better ones??
thanks
summit link
I'm considering to buy also
manifolds #2176
And
EDL-1406
 :feedback: :naughty: :newbie:
Rather push a mopar than drive a Ford
Re: searching a cam
« Reply #1 on: February 20, 2006 - 09:53:50 AM »
that is a lot of durtaion & virtually no lift a far better cam would bre the Engle K k54 or K 56 , the K 54 has 214* duration @ .050 & 255 ad with .470 lift & the K 56 has 224* duration @ .050 , 272 ad & .504 lift
www.EngleCams.com
 If you can find an LD4B intake it is specifically designed for the samller port 318 heads
« Last Edit: February 20, 2006 - 09:55:38 AM by Chryco Psycho »
Offline matt63
Re: searching a cam
« Reply #2 on: February 20, 2006 - 09:57:10 AM »
I'm sure Hughes could come up with a good recommendation also.  They are not hard to get on the phone and specialize in Mopar.  http://hughesengines.com/
Matt in Edmonton
'68 Valiant
Re: searching a cam
« Reply #3 on: February 20, 2006 - 10:00:29 AM »
Engle used tro grind Hughes cams until dave wrecked his relationship with Engle , no I do not know who grinds for Dave But engle is awesome to deal with , personally I have stuck with Engle
Offline 71383bee
Re: searching a cam
« Reply #4 on: February 20, 2006 - 01:41:54 PM »
A lot of 318 rebuilds lately.  CP's cam choice looks nice.  I have had good luck with Racer Browns cams too.  Don at FBO can help you out.  His iron headed 318 is laying down near 10's in the 1/4 with no laughing gas!  www.4secondsflat.com
If you want to save some money then look for any year 340 intake.  They bolt right on and are a very good intake design.  The only downside is the weight.  The LD4B is also a decent choice.  Ive seen that one on a friends 318 and even with the 2BBl cam it woke it up quite a bit.
The edelbrock cams are designed off of a chevy lifter size and are not the right cam for the larger lifters of a mopar.  Believe me the super econo one size fits all packages do not always work good.
You need to state what your goals are with your ride.  Is this a street driver?  Do you have a quarter mile or horsepower goal?  Is this an auto or manual?  I am assuming it is for an E body...What is the rear gear ratio?
These questions will help to better determine a cam for you.
71 - 383 FC7 Super Bee
Offline cuda340shaker
Re: searching a cam
« Reply #5 on: February 20, 2006 - 07:50:18 PM »
What is the highest lift that can be used without machining the heads or changing valve springs?
Re: searching a cam
« Reply #6 on: February 20, 2006 - 08:12:28 PM »
you should ahve clearance for .510 lift without machining but I recommend changing any 30 year old valve spring
Offline Dosz
Re: searching a cam
« Reply #7 on: February 21, 2006 - 03:07:35 AM »
thanks for the information.:thumbsup:
I checked those cams out.  put them into DD2000 but seems to me the edelbrock
is still beter than those ones.  The  Hughes cams were allmost the same than those edelbrcks
Do I something wrong or is there so little difference between cams????
Take note that I'm not very technical, so I just put in the figures I found on the website and check the difference
If anybody has dynodesk2000 cams profiles I'll be glad to have them  :naughty:
