Author Topic: Under Rocker Panel Paint?  (Read 2654 times)
Offline Cannibal94
Re: Under Rocker Panel Paint?
« Reply #15 on: February 23, 2006 - 05:18:29 PM »
Thanks for the pix!  next time you have a tape measure, would you measure that for me?  From the bottom to the masking tape line?  Thanks
Offline Mt.St.BigBlock
« Reply #16 on: February 23, 2006 - 07:13:33 PM »
Hi,  Sure I can measure it for you but if you still have the moulding clip nail
heads on your rocker panels those would make a perfect guide as to where
to mask. I'll probably get back out there tomorrow aft.    Jeff
71 cuda 383 3spd manual gy9
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #17 on: February 23, 2006 - 08:55:22 PM »
Would also be intersted in measurements as I'm creating a car now. :)
2013 Tige' RZR 343hp
Offline FY1 RT SE
« Reply #18 on: February 24, 2006 - 09:54:30 AM »
Upon further review I scrapped the paint off on both sides of the line and there is definately black UNDER the y9
and only primer under the black.
They painted both the rockers and the tail panel (Organosol) before the body was painted.
« Last Edit: February 24, 2006 - 05:29:18 PM by FY1 RT SE »
Offline Cannibal94
« Reply #19 on: February 24, 2006 - 11:27:31 AM »
It is hard to see it, which I guess is the point of doing it, but I found a couple of pics.
« Reply #20 on: February 24, 2006 - 08:00:54 PM »
Hi, Here are some measurements and pics showing how I took them. The first is
from the bottom of door gap to top of the blackout which is 7/8 inch
 Next one is bottom front fender right behind wheelwell opening 2 1/8 inches
 Next is about half way between the two fender bolt holes 2 9/16 inches
 The last is the back of the fender at the door gap edge 2 3/4 inches
All of these fender measurements are from the masking line(3inch on tape) to the very
bottom crease in the fender where it folds in parallel to the ground. In the pics
the fender is off the car on saw bucks. Hope this helps   Jeff
Offline Cannibal94
« Reply #21 on: February 25, 2006 - 08:40:49 AM »
So it looks like the rocker molding actually covers the body color and the black starts at the bottom of the molding.  thank you so much for the pics!  Now I want to find a car with white billboards and see what they did with those!
