Author Topic: Petroleum vs. Synthetic Motor Oil. Waddaya use?  (Read 2512 times)
kudakidd
« on: February 22, 2006 - 11:18:56 AM »
A question recently asked, piqued my interest in knowing what most of you use in your CLASSIC Mopars. Don't care about your daily drivers, just your beloved Mopes. I'll start:
Petroleum (Valvoline Racing) 20w-50
Oldschool
Re: Petroleum vs. Synthetic Motor Oil. Waddaya use?
« Reply #1 on: February 22, 2006 - 11:24:50 AM »
   :iagree:   The Beast takes the same thing KK---Valvoline 20W-50.  Good stuff
« Reply #2 on: February 22, 2006 - 11:44:58 AM »
Mobil One 10W30.
« Last Edit: February 22, 2006 - 11:47:45 AM by MEKrunner »
« Reply #3 on: February 22, 2006 - 11:50:41 AM »
Castrol Syntec 5w-50
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #4 on: February 22, 2006 - 11:52:50 AM »
Mobil-1  5w-50
71fish - Nobody better than an E-BODY!!
Offline Mopar73340
« Reply #5 on: February 22, 2006 - 02:03:13 PM »
I use MOBIL 1 in all my vehicles
Offline Cannibal94
« Reply #6 on: February 22, 2006 - 02:20:19 PM »
Valvoline 10W30
Offline firefighter3931
« Reply #7 on: February 23, 2006 - 11:38:03 AM »
Vr1 20/50 racing oil here.  :burnout:
Ron
68 Charger RT street/strip Bruiser & 70 Charger RT 440-6pack the ultimate Cruiser
Offline Stacked440
« Reply #8 on: February 23, 2006 - 03:28:57 PM »
For first start im using Valvoline 10W-30 as you don't want to run synthetic the first oil change or 2, you want your rings to seat well in the cylinders, then im moving to an all synthetic Amsoil
-Kyle-
Offline KellysCuda aircard
  • Its good to be blown
« Reply #9 on: February 23, 2006 - 04:08:42 PM »
Royal Purple  :screwy:... :money:, freakin oil change takes a home builders loan.
Offline Got JOB
  • Member since 2-14-06
« Reply #10 on: February 23, 2006 - 07:01:58 PM »
Hav-O-Line 10w30 in all three. All are 340's
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
Offline dimples
  • (dodgetkboy78)
    • American car and truck forums
« Reply #11 on: February 25, 2006 - 04:17:30 AM »
 :bananasmi
Royal purple here too, 30W, and 10-40 for the trucks in the winter.
The oil burner gets the cheaper 5W30 Mobil synthectic.
Offline matt63
« Reply #12 on: February 25, 2006 - 08:40:39 AM »
Hughes Engines has an interesting bulletin they send out with their cams.  It basically says that the newer SL/SJ/SM/EC grade oils have far less anti-wear additives than is required for flat tappet cam engines as this reduces catalytic converter contamination.  The lower zinc/phosphorous levels can cause premature wear especially in the camshaft.  They recommend an additive such as Federal Moguls Engine Lube.  Synthetic oils are not recommended for flat tappet cams.  The engine shop I have used says that they have seen many cam failures in recent years and attribute them to the lack of adequate lubrication.
Matt in Edmonton
'68 Valiant
Offline dimples
  • (dodgetkboy78)
« Reply #13 on: February 25, 2006 - 06:09:27 PM »
If that is the case, then running "C" rated oil's, such as DELO, Del-Vac, Rotella, or "C" rated oils for diesel engines would be better, right?
(Higher Zinc and Phosphate levels)
Royal Purple "Synerlec" is also made to cure these problems with the newer oils.
Offline matt63
« Reply #14 on: February 26, 2006 - 10:19:37 AM »
I dunno about the diesel oils.  They have other requirements such as keeping the soot in suspension.
Matt in Edmonton
'68 Valiant
