If that is the case, then running "C" rated oil's, such as DELO, Del-Vac, Rotella, or "C" rated oils for diesel engines would be better, right?
(Higher Zinc and Phosphate levels)
Royal Purple "Synerlec" is also made to cure these problems with the newer oils.
