Yes they are all able to take a conversion. I had a similar problem on my Challenger. I had a nice RT hood for it but it was left laying flat in some grass for a very long time an all of the under side (bracing) was all rusted. I found a nice flat hood that had some top side damage and I was thinking of doing the same thing as you, then I started looking at it. I figured out that the underside could be taken out of both hoods and I could put the good bracing under the RT hood. This was actually easier than it looks. If you do remove the under bracing you can get to the top side very easy to beat our any dents, then replace the lower side. Hope this helps.
