Author Topic: 340 Cuda timing marks  (Read 4611 times)
Stetch1
« on: February 27, 2006 - 04:04:59 PM »
My brother needs a little help with his 70 cuda. He's having trouble finding the timing mark on the block. The 340 is pumped to 500hp and is running hot. He thinks the timing is off but man that thing sounds great at idle. He told me he found the ballancer mark on the passenger side when he lights it up with the timing light. Is there a pin or flag missing? Any and all help would be appreciated.
Re: 340 Cuda timing marks
« Reply #1 on: February 27, 2006 - 05:41:14 PM »
There should be some scale on the block to measure the timing. I guess his is missing??? It looks like some type of plate. If the car idles well, maybe the problem is something else. Can you give us a little history on the engine? Is this a new problem? Is this a newly rebuilt engine? Do you know what size radiator is in there(22, or 26 inch)? Does it run hot in traffic, or out on the highway? I'm just trying to help narrow the problem a little.  :grinyes:
Offline matt63
« Reply #2 on: February 27, 2006 - 06:30:48 PM »
The timing marks are cast into the timing chain cover on the driver's side right.  The damper should at least have one line on it and perhaps other timing marks if it is an aftermarket unit.
Matt in Edmonton
'68 Valiant
Offline Got JOB
  • Member since 2-14-06
« Reply #3 on: February 27, 2006 - 07:00:09 PM »
Early model small blocks had the timing chain covers with the timing marks cast on the passenger side. You could have a late model timing cover and early model balancer on the motor.
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
« Reply #4 on: February 28, 2006 - 12:04:02 AM »
this is exactly why I time by ear , no light
Stetch1
« Reply #5 on: February 28, 2006 - 07:32:42 AM »
Thanks all for the info, here is some more of what he told me. Its a four core radiater, waters is running through just fine he has two electric fans behind it. He bought the car about 18 mounths ago from a friend who did the rebuild.I have been in the car and it goes no hesitation just flat out flies. He said it gets hot idling on warm days 75-80. How do you differentiate between early and late small blocks? I will talk to him about all these things heck I will tell him to join this site and give you guys his story. Again thanks, Still hunting for my Chally.  I had 2 (70slant6, 71 383mag) at one time.
Stetch1
« Reply #6 on: February 28, 2006 - 08:09:53 AM »
Ok here is some more info Cal my brother told me his motor was manufactured in 68. He knows that the timing mark on the block should be on the pass sidewhat he doesnt know for sure is if thewre was a bolt on pointer or a tag mounted on the block. Does anybody khow? Amnd where can he get the right
(part)?
Fred
PS (username)there should of been an r after the first t good thing i didnt put an n in front of the second
Offline 4Cruizn
  • HEMI FISH
« Reply #7 on: February 28, 2006 - 10:14:33 AM »
Stetch1  . . . curious why you are now a guest??  If you need assistance, please let a MOD/ADMIN know!   Welcome (I think) to the site!   :wave:
Offline stretch1
« Reply #8 on: February 28, 2006 - 11:32:11 AM »
As I said in my last reply I mistyped my sign in name so I dumped the old one and typed it in correctly this time.  :jumping:
Offline Got JOB
« Reply #9 on: February 28, 2006 - 06:01:38 PM »
Here is a picture of a timing chain cover for a 71  340. The area painted white is the casting of the timing marks.
« Last Edit: February 28, 2006 - 10:41:40 PM by 4cruzin »
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline stretch1
« Reply #10 on: March 01, 2006 - 07:42:26 AM »
Thanks for the pic "got job". Does an earlier 68 340 use the same cover?
Offline Mopar73340
« Reply #11 on: March 01, 2006 - 04:49:17 PM »
The 68-69 should have the marks on the passenger side of the cover.
« Reply #12 on: March 04, 2006 - 10:44:50 PM »
  shot in the dark, make sure he is running a thermostat, I've always heard that w/o t'stat coolant runs thru the radiator so fast it doesn't have a chance to cool down and this shows up at idle worse for some reason I'm not sure of
