Author Topic: 1971 'cuda Hemi 1/4 mile 169 mph @ 8.32  (Read 4330 times)
Offline JimCuda
  • MOPAR > Move Over Plymouth Approaching Rapidly
« on: March 04, 2006 - 01:53:23 PM »
Ahhh my favorite ride to watch. I only wish I had one.
Title is:
71 Cuda with hemi engine! Very fast! She runs 8.32@169mph in the video! Her best time is 7.44 at 196mph!!!
http://videos.streetfire.net/search/cuda/0/BE988332-9036-4A30-ADDE-129C17247288.htm
 :wow:           :wow:            :wow:            :wow:            :wow:
Also make sure you check out the other cuda & challenger videos on the site.
Oldschool
Re: 1971 'cuda Hemi 1/4 mile 169 mph @ 8.32
« Reply #1 on: March 04, 2006 - 06:51:08 PM »
Cool!   :burnout:  That looks like fun..........    :cooldancing:    ...Oldschool
Offline Carlwalski
« Reply #2 on: March 04, 2006 - 10:30:40 PM »
Cool!!!! Thanks for that mate!  :thumbsup: :ylsuper: :bananasmi
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 71340RT
« Reply #3 on: March 08, 2006 - 12:06:36 PM »
Ya gota love the sound, burnout, and the run down the strip. COOL!!
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline willhaven
« Reply #4 on: March 08, 2006 - 11:44:22 PM »
They've got TurboCuda's car on that site too! Makes me want a TT car bad. :)
Offline JimCuda
« Reply #5 on: March 11, 2006 - 10:07:59 PM »
Twin turbo is a ton of work in custom exhaust work and air tunnel work, you might consider a belt driven super charger.
Offline 4Cruizn
  • HEMI FISH
« Reply #6 on: March 12, 2006 - 10:19:26 AM »
Looks like fun!!   :bananasmi   :bananasmi
Offline JimCuda
« Reply #7 on: March 12, 2006 - 10:36:51 AM »
I hope to have another cuda this year, it has been way too long and when I do I plan on supercharge'n it up!
« Last Edit: March 17, 2006 - 04:58:01 PM by JimCuda »
Offline turbocuda
« Reply #8 on: September 23, 2006 - 10:47:59 PM »
 I know this is old but I feel honored....someone made the compilation and posted it on streetfire...cool....  Been busy with life lately and should be back up and running real soon...finally got injection figured out but had hurt the motor doing so....back stronger and faster......
New resto block, callies crank, boost ready ross pistons, manley pro-series rods, custom turbo cam, edel heads, victor intake w/ 72 lb injectors, twin 61mm p-trtim turbos, new strange 60, wilwood brakes and freshly rebuilt 727 with billet steel drum, extra clutches, ultimate sprag and billet steel stator installed in PTC 9.5 converter.....See you in a video soon with 9 second passes.
Offline willhaven
« Reply #9 on: September 24, 2006 - 09:24:06 PM »
What time was it running before you killed the old engine?
Also, I'm located in Raleigh (if you remember). Are there any local clubs or shows or cruises that happen often? I'm new to the hobby and want to know where I can run into local guys with nice rides. I saw a guy driving down Walnut the other day with a 71 Challenger convertible. If I hadn't been so busy I might have ran him down to ask him some questions.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #10 on: September 25, 2006 - 09:43:46 AM »
Very cool video!  That car sounds sick!!!!  :thumbsup:
Offline turbocuda
« Reply #11 on: September 25, 2006 - 08:00:45 PM »
Went 6.64 at 106 at piedmont on 10 psi. I had just found the ignition problem that had haunted me for 2 months. I feel the motor was already hurt and the head gasket decided to let go. I roll with some guys here in Durham with some fast cars. Not much into the shows and stuff but plan on being out cruising soon.
Offline JimCuda
« Reply #12 on: September 26, 2006 - 07:34:52 PM »
Cuda is here and rolling with some friends at the local turbo shop I think thats the route I'm going.
Question is, either supercharged or turbo. Anyone got any good carb ideas or cheap efi that will run well with boost?
Offline turbocuda
« Reply #13 on: September 26, 2006 - 08:13:25 PM »
Use a small(650) double pumper with the choke horn cut off, choke holes epoxied and run dual powervalves....put big jets in the back to get extra fuel under boost(over 10 # diference) and use a boost reference regulator.  A very easy setup to deal with and fairly easy to tune....also run a good bonnet such as a CSU.
My buds camaro has gone over 130mph in the 1/8th with 355ci 23deg heads with a 91mm and a holley 650 at 3100lb.
Offline turbocuda
« Reply #14 on: September 26, 2006 - 08:21:11 PM »
More recent pic
