Author Topic: Differneces in 440 6 bbl center carbs  (Read 934 times)
Offline jshoop
  • I'm a llama!
« on: March 04, 2006 - 08:58:16 PM »
Does a 440 6bbl with a four speed take a different center carb than an automatic one?  Do they take the same outboard ones?  I was looking at 4175-1, 4144-1, 4365-1 and wanted to know if they were right for a four speed car.  I am not concerned with them being numbers matching correct.
Re: Differneces in 440 6 bbl center carbs
« Reply #1 on: March 05, 2006 - 01:16:23 AM »
they are tuned slightly differently as there is a bit more load on the engine at idle with the auto , the secondaries are the same
Offline jshoop
  • I'm a llama!
« Reply #2 on: March 05, 2006 - 10:28:02 AM »
So, could they just be retuned?  Are they jetted different?  Also did you mean that the secondaries were the same for a four speed and an automatic car or that they were also tuned differently?
« Last Edit: March 05, 2006 - 10:57:21 AM by jshoop »
« Reply #3 on: March 05, 2006 - 01:45:09 PM »
the secondaries were rthe same for both 4 spd & auto & yes you can tune the carbs , this should be done anyway
Offline jshoop
  • I'm a llama!
« Reply #4 on: March 05, 2006 - 02:44:15 PM »
Okay, I got the secondaries down.  One more question then I'm done.  Can the center carb be tuned to run with an automatic or a 4 speed?  No different linkages on it or anything (other than part numbers) to make them look any different?
« Reply #5 on: March 05, 2006 - 03:02:26 PM »
yes it can be tuned , the linkages etc are the same
