Author Topic: Hydra Boost for Brakes  (Read 1344 times)
Offline 73EStroker
« on: March 06, 2006 - 10:05:53 PM »
Has anyone used a Hydra Boost for their brakes in place of the vacuum booster.? Apparently they give good boost when at low engine RPM if you have a wilder cam. A friend of mine has a BB Corvette and he claims a huge improvement. His unit came off a 1 ton Chevy Van. You have to ditch the existing booster and these units rn off the power steering pump.
Regards, Barry
Barry (Salmon Arm)
Re: Hydra Boost for Brakes
« Reply #1 on: March 07, 2006 - 02:18:41 AM »
they work well , I have seen kits to adapt them
Offline TKat13
  • Work In Progress...
    • Project Cuda
« Reply #2 on: March 07, 2006 - 06:20:58 PM »
Is this the same system used on the '04 Mach 1's and Cobras? I think so, if so, then my brakes work great and saves a ton of space. Curious on whether or not they could be put on a Mopar.
1974 'Cuda
2005 SRT-10 Ram
2006 Buell Firebolt XB12R (Murdered by person texting & driving)
2004 Mach 1
« Reply #3 on: March 07, 2006 - 11:12:10 PM »
I see no reason why they could not be adapted
Offline 73cuda426
« Reply #4 on: March 10, 2006 - 03:15:14 PM »
I had a friend put 13' baer rotors w/ hydraboost kit and he says the car stops on a dime...so I bought kit w/ new master cylinder that they suggest and put in their custom bore b/c they don't like the bore of baers kit. Will reply when mine are in.
« Last Edit: March 25, 2006 - 08:15:38 PM by 73cuda426 »
Offline Bamakx
« Reply #5 on: March 20, 2006 - 07:42:14 AM »
I got my system for www.lateral-g.net/products/hydratechbraking/.  They are great two work with and the system works out of this world.  All you need is power steering.
73 Challenger 440 727 with Over drive
