Author Topic: Mirror glass removal  (Read 1983 times)
Offline GCC
« on: March 08, 2006 - 06:57:26 AM »
What is the trick to remove the side mirror glass without breaking it so it can be re-used or replaced?  '70 Barracuda chrome non-remote mirror.
Offline Total BS
  • '71 Carrabuda Baby!
Re: Mirror glass removal
« Reply #1 on: March 08, 2006 - 09:45:28 AM »
GCC,
If you can angle the pivot of the mirror far enough to one side you should be able to get a flexible screwdriver behind the glass to remove the two screws that hold it and remove the whole assembly.  One screw on each side.
I sprayed the screws with some PB Blaster and let them sit over night.  I had two sets of mirrors. Two worked beautifully and the other two I had to break the glass to remove the screws. Replacement glass is available on ebay. Here is a picture of the screws.  Hope that helps.
1971 'Cuda 383
1970 Chevelle SS LS6
1999 Durango
-New Joisey-
Offline GCC
« Reply #2 on: March 08, 2006 - 10:25:03 AM »
Thanks for the reply & photos, but I have the chromed, non-sport mirror.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #3 on: March 08, 2006 - 04:59:06 PM »
I saw a post on another board that said to soak the mirror glass down in a tray filled with Goo Gone overnight to melt the glue and it will pretty much fall off.I haven`t tried it yet so don`t know if it works.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
