Author Topic: Intake Swap  (Read 1252 times)
Offline 71383bee
Intake Swap
« on: March 08, 2006 - 08:48:47 AM »
I was wondering about swapping my plain jain perfromer intake to a Holley Street Dominator i got with a 400 core.
The motor is a low compression (around 8.2:1) 30 over 383 with KB 162's, larger port 906's that have been cleaned up, a XE 268H cam with 224/230 duration @ 0.50 and .477/.480 lift, and a 650 Mighty Demon.  The car is a 71 Super bee (around 4k in weight) with a 727 (around 2700 stall) and 3.91 gears on 15" rims.
This is a 90% street car so low end is a concern and i am a bit concerned about going to a single plain, but i have heard such good things about this intake it might be worth a try.
What do you think?
71 - 383 FC7 Super Bee
kudakidd
Re: Intake Swap
« Reply #1 on: March 08, 2006 - 09:45:08 AM »
You may lose a bit of bottom end snap, but a big block swap is so easy, it's worth a try.
Re: Intake Swap
« Reply #2 on: March 08, 2006 - 12:20:49 PM »
I would be doing the swap , the performer was not much of a performer
Offline 71383bee
Re: Intake Swap
« Reply #3 on: March 08, 2006 - 01:54:09 PM »
I agree with that...the reason i ask is that i am not adverse to obtaining an RPM which I believe is the right manifold for my needs, but i have this SD sitting on the bench now collecting dust and i was curious if it would be too much of a mismatch to be worth it or am I better off just shelling out the dough and getting the RPM.
OBTW I have a 1" phenolic 4 hole spacer on the car now.  Should that go on the SD too?
Re: Intake Swap
« Reply #4 on: March 08, 2006 - 02:23:49 PM »
if you have room the 4 hole spacer should increase the resposiveness at the c arb & help low end power , but the SD doesn`t kill the bottom end entirely as it is a small runner design
Offline 71383bee
Re: Intake Swap
« Reply #5 on: March 08, 2006 - 04:11:38 PM »
Cool,
So it sounds to me like it is a go.  I'll give it a try in a month or so once the weather warms up.
Re: Intake Swap
« Reply #6 on: March 09, 2006 - 12:06:20 AM »
let me know what you think of the change , I have done this with other car & never had a disappointed customer
