Author Topic: Secondaries: Vacuum or Mechanical?  (Read 2242 times)
Offline 71chmark
« on: March 09, 2006 - 09:28:25 AM »
Which is better?
I may be schizophrenic,
Re: Secondaries: Vacuum or Mechanical?
« Reply #1 on: March 09, 2006 - 10:10:41 AM »
That's a toughie without more info. Stock or built-up? Auto, or stick shift?
kudakidd
« Reply #2 on: March 09, 2006 - 10:28:30 AM »
With a stick, I've always prefered mechanical secondaries (double pumper) :thumbsup:
« Reply #3 on: March 09, 2006 - 01:05:21 PM »
I prefer double pump carbs too
« Reply #4 on: March 09, 2006 - 02:30:08 PM »
Yeah,
   Even in my automatic car, the old Holley double-pumper is a killer.  :burnout:
Offline EVIL72
« Reply #5 on: March 09, 2006 - 04:38:15 PM »
 I've always liked Double pumpers better, but I've always run single plane intakes with an automatic.  How is the Double pumper for a duel plane with an automatic compared to a vac secondary? Is the double pumper still better?
 I picked up my first duel plane which is an Air Gap RPM for my 340 and happen to have a 700 DP laying around.
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
« Reply #6 on: March 09, 2006 - 05:45:10 PM »
I am by NO means an expert, but I just could never get a vacuum secondary carb to work for me(I have an automatic). I have a duel plane, but that isn't the problem. I always had a slight bog when I floored it. I tried messing with different secondary springs, but I never solved the problem. Since the double-pumper always did the trick, I'm sticking with it.  :burnout:
Offline sccarts1
« Reply #7 on: March 09, 2006 - 11:25:04 PM »
i always prefered mechanical 'cause the let you control the WHEN !!! especially on multi-carb cars. there's nothing more annoying or more dangerous than a high powered car that launches on you unexpectedly.. also they make launching.
with street tires more do-able.
Offline Rob C
« Reply #8 on: March 10, 2006 - 10:25:49 AM »
Vacuum secondarys are very good for gas mileage, heavy cars and general performance useage.
Mech. secondarys are great for 4spd cars, very hi po auto trans cars and excellent for the track. Light cars as well.
This is not to say that the list as writin above can not be reversed, it's just best sutied in this manor and easier to do in that order.
The amount of power the car has along with cars weight, intended purpose, cam size, intake style, rear gears and tire size would be good info to make a recomendation on what carb style and size to use. Sometimes, the info will almost dictate what should be the best choice for your car.
« Last Edit: March 10, 2006 - 10:29:10 AM by rumblefish360 »
'73 Cuda, 360, 4psd & 4.10's
'79 Dodge Magnum, 360, 727, 9-1/4 W/3.55's
Offline Robb
« Reply #9 on: March 10, 2006 - 03:01:32 PM »
 :icon16:   me too.     Chevys, Olds' and Mopars...   double pumpers always came through when the vac secondaries were just flops.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline JCWCuda
« Reply #10 on: March 12, 2006 - 12:01:02 AM »
Big fan of the Good Old Holley Double Pumper myself  :bigsmile:
1974 Barracuda 360
2008 Ram 1500 Quad Cab 5.7l Hemi
1990 Jeep Cherokee 4.0l
Gone but not forgotten
1967 Barracuda 273
1976 Charger 318
2003 Dakota Quad Cab 4.7l
1988 Jeep Cherokee 4.0l
Offline EVIL72
« Reply #11 on: March 12, 2006 - 12:24:37 AM »
I've always had better luck with the DP too.
ROB
