Year One wiring harness
Author Topic: Year One wiring harness  (Read 10424 times)
Offline FY1 RT SE
« on: March 09, 2006 - 01:34:52 PM »
This seems to be asked quite often, so I decided to do some extensive research into the subject.  The wiring harness is a perfect example of you get what you pay for.  Here are just a FEW of differences with the Year One harnesses. Some are visual others are not.
The wire used in Year One harnesses is crosslink polyethylene rated at 125 degree C (257 degree Fahrenheit), other manufactures harnesses are rated at either 85c or 105C (185/221 Fahrenheit) or a mixture of both.  The crosslink polyethylene is non combustible and stays flexible and in theory any device that shorts out will only take out that circuit and not the entire harness.
All hard shell connection systems are molded out of Nylon 6.6 instead of polypropylene, the benefits are higher temp rating, better elasticity and chemical and ozone reflective properties.
All terminal crimps are done to pass industry standard pull tests.  In addition terminals are the original manufactures or duplicated to the originals, they are not some modified terminal made to fit.
All molded connection systems are molded out of a high temp rated flexible material, rather than the less expensive PCV that hardens after a few years.
Solder is leadless thus environmentally friendly.
Complete harnesses only are built.  If there is a huge differential in the price of the harnesses ask questions.
Electronic conversion harnesses are built to performance standards as to wire length and resistance standards.  This means that the ECU’s must be placed on the firewall, where Chrysler designed them to be.  Extended length wire affect resistance thereby affecting the performance of the ECU’s.
Below are some differences in connectors.
Offline FY1Challenger
  • I'm a llama!
Re: Year One wiring harness
« Reply #1 on: March 09, 2006 - 02:02:11 PM »
Much as I hate to buy from another retailer, as opposed to the source, Yr. One harnesses are the industry standard. Buying on the cheap may come back to burn you...literally!  :working:
Offline zerfetzen
  • 'Cuda, should'a, would'a...you lost.
« Reply #2 on: March 09, 2006 - 02:11:48 PM »
A few months ago I bought and put in the Year One dash harness, as well as their engine harness, on my 73 Cuda.  I'm so happy with them that when disposable income rears its head again, I'm going to get both the forward and rear harnesses.
I thought it was going to be painful tracing every wire down to double check (so I bought a wiring diagram, which I'm still glad to own), but the new Year One looked like the old Plymouth harness, only like noted, with better wire and insulation.  Hats off to Year One's Cuda wiring harnesses.
« Reply #3 on: March 09, 2006 - 02:47:17 PM »
Just to let you know about those forward and rear harnesses... I bought both for my 70 Challenger. My rear probably didn't need replacing since the wiring was all inside the car anyway, but I went for it. I liked the Year One harness there, but the sockets for the two side marker lights were kind of cheap. I had to work with them to get them to make a good ground contact. My front harness was a peach!!!   :woo:  It even had provisions for my front fender turn signal indictators.  :bananasmi  So yeah, I would do it all again for sure.  :cheers:
Offline Carlwalski
« Reply #4 on: March 09, 2006 - 04:15:47 PM »
I've said it before but the Year One harnesses were the best product we purchased from YO.
That's with over 40+ Orders of parts so that's got to say something!!!!
They stock every loom needed except for the power window looms.
10/10 IMO.  :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline hotrod98
    • Maniac Musclecars
« Reply #5 on: March 09, 2006 - 05:09:55 PM »
Does anyone know anything about the wiring harness in the wiper motor switch area? I don't see a seperate part number for the 3 speed style. I bought a Year One dash harness for my 70 challenger and it looks like it's for a 2-speed. The switches in the dash have completely different connectors so it seems impossible to have the same harness fit both switch styles. When I installed the shaker hood on my 71 cuda, I had to convert to the 3-speed motor. I have yet to figure out how to connect it so that it will work. The wiper harness that they sell is for the 2 speed wiper motor. Any ideas. Rainy season is almost here.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #6 on: March 09, 2006 - 05:39:59 PM »
Honestly that is one area no one should scrimp on, buy the best made wiring you can find, any price difference will be worth the peace of mind knowing that your car is as electrically safe as possible. Also if you need all sets, buy them as you can but unless there is no way around it, I'd say wait and install them all at the same time, perhaps not necessary, but what a good feeling it should give you.
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline 472 R/T SE
« Reply #7 on: March 09, 2006 - 06:00:31 PM »
I hope you weren't comparing with who I go thru. :bricks1:
Bill Evans Custom Wiring
8835 Parson Rd.
Erie, PA 16509
(814) 864-2622
HELP SUPPORT THE REGISTRIES because all cars matter.
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Offline 70RTdroptop
  • 1970 Challenger R/T 440-SixPack
« Reply #8 on: March 09, 2006 - 09:12:22 PM »
Definitely Year One is the way to go for harnesses. I've purchased them for both my Charger RT and my Challenger, and they fit and function perfectly.
1970 Dodge Challenger R/T 440-6 convertible
1966 Ford Mustang convertible  - numbers matching (wife's car )
