Author Topic: Dang i got bad ebay luck,4 speed OD questions  (Read 25806 times)
Offline moparnut
    • My Photo's
« on: March 09, 2006 - 10:30:48 PM »
The tranny I bought on ebay the seller was flakey and tried to charge me more shipping than the auction stated after i paid,He just didnt get that after the auction ended,you cant change your terms.I am tired of deadbeat sellers,so I got my money back and am rethinking going with a 4 speed OD unit,any web pages or instructions on the OD swap?What has to be changed?
thanks again,hopefully one day this will end,i'll get the tranny i paid for and will be able to move on,lol
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Re: Dang i got bad ebay luck,4 speed OD questions
« Reply #1 on: March 09, 2006 - 10:59:39 PM »
depending what belhousing you have you need to cut the front brg retainer needs to be cut down to 4.80 " to fit the belhousing , & the 3-4 shift rod needs to be bent Little to clear the crossmember
Offline moparnut
    • My Photo's
« Reply #2 on: March 09, 2006 - 11:57:37 PM »
Well since i will be getting all the stuff to swap in(and bagging the original stuff) I dont have the beel housing or the tranny yet.Any suggestions on the right bellhousing?Will the truck bell housing work that the OD 4 speed came with if i can find one?thanks for all your help Chryco
« Reply #3 on: March 10, 2006 - 12:05:09 PM »
the small block bell form a 318 OD truck is perfect for any small block E body & ther eis no reaso nto cut down the brg retainer doing it this way
Offline moparnut
    • My Photo's
« Reply #4 on: March 10, 2006 - 05:56:55 PM »
Time to go wrecking yeard hunting,thanks!!! :working:
Offline 4spdChally
« Reply #5 on: March 13, 2006 - 11:07:41 PM »
I just picked up an NOS smallblock OD bellhousing for $40.00 for my Challenger. You should be able to find one pretty easily from a truck. The clutch fork is special for that bellhousing so when you find one grab it too.
« Reply #6 on: March 13, 2006 - 11:47:22 PM »
doesn`t hurt to grab the flywheel  & linkages  & the driveshaft yolk as well
Offline moparnut
    • My Photo's
« Reply #7 on: March 14, 2006 - 09:29:54 AM »
Thanks for all the help,I am sure a truck bellhousing should be easy to find.Does it matter which SB truck bellhousing to use?Or is there one for all 4 speeds trannies for the years Chryco stated?Does the OD really help on the freeway?thanks again
« Reply #8 on: March 14, 2006 - 11:08:45 AM »
all trucks use the same belhousing ,
 the OD really helps on the highway , multipy yur rpm at any given speed by .71 & that will be the new RPM
Offline MyMopar
« Reply #9 on: March 14, 2006 - 12:23:38 PM »
Hey Chryco, I thought you had to invert the lever on the OD tranny?  I'm not sure if it was the 3-4 or the reverse.  Perhaps I'm wrong but I could swear I reversed something when I did the swap in the Charger years back.
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
Offline 73EStroker
« Reply #10 on: March 14, 2006 - 09:29:32 PM »
 :canada:
Hey MOPARNUT - talk to Chryco. He rebuilds and sells OD A833s for reasonable prices. Don't know where you are cause shipping may  :'( hurt you.
Barry (Salmon Arm)
Offline moparnut
    • My Photo's
« Reply #11 on: March 14, 2006 - 10:53:36 PM »
I am in central calif,probably too far to ship,I would however like to buy something from Chryco since he is always so helpfull.He has way more patience than i will ever have :bigsmile:
« Reply #12 on: March 14, 2006 - 11:24:01 PM »
the 3/4 lever is inverted / down on the OD requiring a slight bend in the 3/4 shift rod to clear the cross member by the shifter
 I could ship one not sure what it would cost though
Offline moparnut
    • My Photo's
« Reply #13 on: March 15, 2006 - 08:13:19 AM »
Thanks for your help Chyco,they are heavy and I am sure the shipping would kill me so I am looking locally,not in any real big hurry.
Offline MyMopar
« Reply #14 on: March 15, 2006 - 08:53:36 AM »
I'm in the shipping industry and could probably get you a reasonable rate if interested.  However the best rates would be if you dropped the freight off and picked it up instead of having it delivered.  As an example, I shipped an entire front end for someone on a pallet using economy service and it was $48.  Not too bad.  If interested jsut post up the zip codes or PM me and I can let you know.
Personally I wouldn't want to mess around with a junkyard tranny, a rebuilt one would be the way to go, considering the time involved to install/uninstall and repair if not up to par.
