Dang i got bad ebay luck,4 speed OD questions
Author Topic: Dang i got bad ebay luck,4 speed OD questions  (Read 25807 times)
Offline moparnut
    • My Photo's
Re: Dang i got bad ebay luck,4 speed OD questions
« Reply #135 on: April 17, 2006 - 12:47:00 PM »
Well they called back and said they didnt have the fork,I guess these are still available from the dealer or other sources?I did buy a "nice" flywheel from the same truck for 35 bucks(already had one but figured a spare would be nice for that price)He isnt charging me anymore freight since he didnt have to fork.He did also measure the hole and its 5 1/8th-ish so its probably the right one.Now my search for the fork............................
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline ShelbyDogg
« Reply #136 on: April 17, 2006 - 12:56:20 PM »
Chryco said he had 3 or 4 of those ball type forks on page 4. If you're nice to him, maybe he'll sell you one.
Offline 4spdChally
« Reply #137 on: April 17, 2006 - 02:18:10 PM »
I don't know about other sources but, Yes the fork and ball pivot are still available new from the dealer.
« Last Edit: April 17, 2006 - 02:26:54 PM by 72redChally »
Offline moparnut
    • My Photo's
« Reply #138 on: April 17, 2006 - 02:20:27 PM »
thanks,Hey Chryco can i buy a fork from you?Or is there export duties?lol
« Reply #139 on: April 17, 2006 - 11:55:14 PM »
I have one & I will sell it to you no prob
Offline moparnut
    • My Photo's
« Reply #140 on: April 18, 2006 - 10:40:06 PM »
I pm'd you Chryco
Offline 1BADFISH™
« Reply #141 on: July 28, 2006 - 06:50:25 PM »
2892482
Is this a good bellhousing to pick up. I think I can get it cheap with free shipping, will it work with an OD833.
http://www.autohobbydigest.com/tables.php?04_Bellhousings
Thanks
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
« Reply #142 on: July 28, 2006 - 07:58:50 PM »
worth looking ta , it doesn`t list the diameter of the front brg retainer though , it needs to be 4.80 or 5.2 "
Offline 1BADFISH™
« Reply #143 on: July 28, 2006 - 08:22:23 PM »
I'll get the guy to check, is aluminum ok? Its on PEI, my buddy may take it with him next week.
Charlottetown, PE
« Reply #144 on: July 28, 2006 - 08:47:00 PM »
most were alum , it is fine
Offline ShelbyDogg
« Reply #145 on: July 28, 2006 - 10:47:48 PM »
Most of the car small block ones I've seen are the small diameter 4.3" front bearing retainers.  Most of the big block ones I've seen have the 4.8' Hole. I have an early big block cast iron one with the 4.3 hole. If it is cheap enough, I would buy it just to keep around since most standard 4-speeds could use it.  Find a truck small block bellhousing with the 5.2" hole and be done with it.
