when you find a truck get the belhousing , flywheel ,release fork , shifter , rods ,
the shifter can be made to work although it is not completely correct , if you are swapping from a 904 you will need a different driveshaft & Yolk if you are swapping from a 727 the same driveshaft & yolk is used
if you get the OD bel the 5.2 brg retainer & hole will already match
the truck Z bar is different , but can be modified to work so get it too as well as the adjuster rod & the rod from the pedal to the Z bar ,it is also different but can be made to work
sometimes the trannys need to be rebuild , sometimes not , it just depends on milage & how it was treated in the truck
