Author Topic: Cuda doors... same all four years?  (Read 859 times)
Offline cudacharlie
  • 70 Cuda convert, 70 Charger R/T
« on: March 11, 2006 - 07:56:04 PM »
Here's a question:  Are Cuda doors the same for all four years, and can be interchanged at will?
My passenger door has only one of the 2inch catwhisker window guides, at the inside top edge at the rear of the door.  On the driver's side it has two, but it looks as though there is room for a third.  The pass door definitely is NOT a mirror image of the driver's door, in terms of mounting locations for these things...  Is that normal, or do I have a 74 pass door that is somehow different?  If I need a new door, can I grab any one from any year?  What differences do I need to watch out for?
Thanks! :dunno:
70 Cuda convert
70 Charger R/T
06 Magnum SRT8
Offline 4Cruizn
  • HEMI FISH
Re: Cuda doors... same all four years?
« Reply #1 on: March 11, 2006 - 09:04:47 PM »
As far as I know they are all the same.   :thumbsup:
« Reply #2 on: March 11, 2006 - 09:14:38 PM »
This is a question about whiskers and I do know the answer to that one.
In 1970 on one side,.. the one facing you, the whisker is put on with screws. From 71 on they had clips that fit the whisker assembly into slots that are on the sheet metal of the door.
« Reply #3 on: March 11, 2006 - 11:50:46 PM »
all fit , the later doors had heavier crash beams in them
