Author Topic: 70-71 versus 72-74 Sun Visors, what's the diff??  (Read 2511 times)
Offline 70GranCoupe
  • I am not a llama, I am a man!
« on: March 14, 2006 - 05:03:44 AM »
Hey Everyone, I am slowly getting up to speed on the differences between the 70 and sometimes 71 and 72-74 Cudas. I see that there is a difference in the sun visors as well. The ones that came with my car are 5" wide by 20" long. I see ones on eBay that appear to be wider than that. Are mine correct '70 visors and the wider ones for later years or vice versa? As always thanks for the input!
Offline hemi71
Re: 70-71 versus 72-74 Sun Visors, what's the diff??
« Reply #1 on: March 14, 2006 - 07:24:35 AM »
The 70-71's have a tab that slides into the center rear view mirror and supports the visors in the middle. The 72-4's are only mounted by the post and have no provision for the center support. Also, the pattern of the 3 mounting screws is different, the later visors have a larger mounting pattern and they will not interchange.
http://cgi.ebay.com/ebaymotors/MOPAR-Cuda-Challenger-Sunvisors_W0QQitemZ4621815524QQcategoryZ34206QQrdZ1QQcmdZViewItem
Here is a set of 72-4 visors....and contrary to the ad text, they will NOT interchange.
[attachment deleted by admin]
« Last Edit: March 14, 2006 - 07:42:10 AM by hemi71 »
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: March 14, 2006 - 09:45:36 AM »
I know that the convertibles had skinner visor's than the hardtops.  As for the rest . . . still learning.   :popcorn:
« Last Edit: March 14, 2006 - 08:10:48 PM by 4cruzin »
Offline 70GranCoupe
« Reply #3 on: March 14, 2006 - 05:18:17 PM »
So what you are saying is that if they have the tips to insert into the mirror they are correct for 70-71??
Thanks!
« Reply #4 on: March 14, 2006 - 05:51:44 PM »
Thanks!
That's the way it works for a Challenger.  :thumbsup:
Offline miketyler
    • www.miketyler.net
« Reply #5 on: March 14, 2006 - 05:57:14 PM »
so did the 72-74 models retain the same rearview mirror base with the slots for the visor tips? All cuda models I have seen have the base with the slots  :1zhelp:
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
« Reply #6 on: March 14, 2006 - 07:52:48 PM »
  my '73 does NOT have slots & tips
Offline hemi71
« Reply #7 on: March 14, 2006 - 08:24:50 PM »
The later versions dont have the slots
Offline ArcticCuda
    • Pepe
« Reply #8 on: March 15, 2006 - 01:44:35 AM »
hemi71. Offtopic but what is your back wheel/tire combo? It's looking GOOD! Is it 275/60 on 15x8?
Current Vehicles:
Plymouth PPR Cuda 1970 489 cid
Plymouth GTX 1970 RS23V0E
Sorry my bad english...I'm just an european...
Offline miketyler
    • www.miketyler.net
« Reply #9 on: March 15, 2006 - 09:46:15 AM »
hmmm...ok. It's too wierd that I have seen so many 72-74's with the 70-71 rearview mirror bases. I have a couple of 70-71 bases if anyone has a correct 72-74 to swap out.
72' Cuda restomod
70 Mustang Mach 1
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #10 on: March 15, 2006 - 10:02:41 AM »
hey 71hemi.. looks like your car is the poster child for Franklin Mint's black cuda..   :picture:
71fish - Nobody better than an E-BODY!!
Offline hemi71
« Reply #11 on: March 15, 2006 - 08:23:02 PM »
Artic...that's 275-60-15's on a custom backspace (3 1/2 BS) 15 X 7.5 Rallye. Needed the custom backspace so the tire would not hit the leaf springs, I'm running the narrower B body Dana 60 rear. Biggest tire i could have mounted on the standard 15 X 7 4 1/2 BS rallye was a 255-60-15. I wanted the "Big-Little" look, so 275-60's on the front and 215-65's on the front.  Decided against white letters for now, when i get bored with it, I'll make up a set of standard 15 X 7's with 255-60 and 235-60 BFG T/A's.
Here is a shot of it from the rear...i took it down low, so it exagerates the rake of the car a bit.
I did not know Franklin Mint had a black Cuda...I have the red ragtop, and I've seen the FC7 Cuda...I'll have to look for that black one! Thanks 71fish!
Offline ArcticCuda
    • Pepe
« Reply #12 on: March 15, 2006 - 11:23:56 PM »
Hi, thanks for info. Look and stance is awesome!
Current Vehicles:
