Custom Std Dash Instrument Clusters - Lets see em!
Author Topic: Custom Std Dash Instrument Clusters - Lets see em!  (Read 5949 times)
Offline GoodysGotaCuda
« on: March 15, 2006 - 12:03:59 AM »
I just bought another gauge that i needed for my barracuda. i now have oilpsi, water temp, and volts hanging under my dash frame in cups. Looks ok...but i do now i have three out of the five gauges i'd need to do a custom dash (speedo & fuel level)  :woo:
So i've decided to pickup a doner instrument cluster bezel at mats and gather the two more gauges to do a swap.
Can i see what you've done? I'm using Autometer Pro-Comps (black)
Thanks!  :working:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline crcarch
  • Happiness is having the time and the money!
  • "No, it's not a Charger!"
    • A little history and restoration pics on Cardomain
Re: Custom Std Dash Instrument Clusters - Lets see em!
« Reply #1 on: March 15, 2006 - 12:05:30 PM »
I haven't done anything to my own, but I had a few photos that you might be interested in.
00/===\00 73 Challenger 440-4V/AT  8/--+--\8 09 Ram 1500  0o\==/o0 05 Crossfire Roadster OO(#####SRT)OO 10 Challenger
« Reply #2 on: March 15, 2006 - 04:29:16 PM »
thanks! that second one looks like what i want to do. just with my black procomp gauges  :bigsmile:
1976 Dodge Warlock
Offline jvhodges
« Reply #3 on: March 15, 2006 - 06:36:48 PM »
I did this on the cold winter days up here, the shift light came from Raptor Performance. If you decide to cut the benzel make sure you leave the upper line on that way it will match the headlight benzel when installed.
Jeff
« Reply #4 on: March 15, 2006 - 06:45:32 PM »
   FWIW I saw recently somene was making a guage housing that replaces the center speaker grille on to of the dash.  :bigshades:
« Reply #5 on: March 15, 2006 - 10:55:26 PM »
Jeff
Looks great! likely i will just be using the standard 2 5/8 gauge holes. I do have one question. How did you go about hooking up the mechanical speedo? did you need a new cable? anything else?
thanx
-Mike
1976 Dodge Warlock
Offline 1BADFISH™
« Reply #6 on: March 15, 2006 - 11:22:10 PM »
Hey Goody, I'm looking into the same thing. I'm thinking Autometer pro-comp Ultra-Lite guages. The holes  are 2-5/8 but this dash here looks to have the guages sunk in further. I'm thining he used the 2 1/16 guages and the 5" spedo and they all sunk into the holes. That way you don't have the guage trim sticking out, but sunk in. Not sure, still trying to get more info, mainly on the mechanical spedo as you mentioned. Check out how the guages sit in this dash, looks pretty good.
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
« Reply #7 on: March 15, 2006 - 11:25:16 PM »
that definately looks good sunk in! now just how to do it!
1976 Dodge Warlock
Offline 1BADFISH™
« Reply #8 on: March 15, 2006 - 11:39:36 PM »
Goody, here is the website I found that got me considering this path. I was looking for a ralley dash, but did a quick search and found this car. For me to properly convert to a ralley dash would be pretty expensive, I have A/C and a 4 switches, so that makes things a little more difficult.
http://popularhotrodding.com/features/0309phr_70cuda/
I'm also looking at what has to be done to do this to a standard dash, I have the tack mounted there already, so its a matter of switching over the rest of the guages. Note from the picture the one oil pressure guage I have that doesn't look right when its sticking out. I think the white face guages sunk in look great.
Charlottetown, PE
« Reply #9 on: March 15, 2006 - 11:49:54 PM »
i think i know what they did!  :rofl: seems so obvious now. instead of pushing the gauge through the hole like you did, they just mounted it from the back side. which is why you cant see the bezel on their gauges, those are 2 5/8".
seems so obvious!! duhhhhhhhhhhhhhhhhh!!!  :rofl: :bigsmile:
1976 Dodge Warlock
Offline MyMopar
« Reply #10 on: March 16, 2006 - 01:44:10 PM »
I will be doing a conversion myself.  After looking through many pics and coming up with ideas this is what I decide on.
I want to keep it as stock as possible but also add a touch of class so Auto-meter Phantom (white face gauge to match white interior) using a 5" speedo and then 2 5/8" tach, oil, water, fuel.  I will flush moun tthe gauge so the bezel is even with the surface, not protrudig and if anything slightly beneath it for a "tunnel or cockpit" look.  For monitoring voltage, I am considering this http://www.customdynamics.com/LED_battery_gauge.htm 2nd one down remote flush mount.  I think that will be cool and do the trick, a single led installed and green would mean good to go.
I'll be sure to take lots of pics when I start and detail the steps.
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
Offline crcarch
« Reply #11 on: March 18, 2006 - 06:51:53 AM »
I like the flush look but I would be concerned that in order to get the 2 1/8" gauges flush from the back, you'd have to cut the front bezel. The "cups" are slanted on the back to fit the slanted gauge lens.  Looks like the smaller gauges are mounted flush against them, so I'm thinking they had to be cut to do that.  I know that from the front, the 2 5/8" fits perfectly in the cups without modification and can simply be clamped down.  That allows them to be completely removed and could go back to stock if you wanted to. :2cents:
