Author Topic: Chryco's NZ Engine Build  (Read 1855 times)
Offline Carlwalski
« on: March 15, 2006 - 01:58:56 AM »
Thanks for the help CP.  :cheers:
Here is the build sheet and a few engine photos. Anything you need to help determine what parts I need or specs ask away and I'll see if I can get them for you. I would like something that is mild, somewhere around 425hp would be ideal.  Nothing to hardcore as I want a solid running daily driver. Bigger/lumpier cam, just a tickle up I guess.
Cheers,
Carl
Engine Build Consisted of:
Refaced Block
Crank Grind
New Billet Camshaft
Hydraulic Lifters
Gasket Set
New Pistons ("030")
Big End Bearing Set ("020")
Main Bearing Set ("020")
Camshaft Bearings
Timing Gear Kit
Oil Pump
Con Rod Bolt Kit
Piston Rings
Crank Damper
Strip, Clean & De-choke Head
Crack tested excellent
Reface Seats
Valve Inlet
Valve Exhaust
Valve Guide "K" Liner
Valve Springs
Valve Keeper Set
Spring Retainers
Valve Stem Seal
Reface Head
CC Head
Vac test Valves, Assemble Head
Assemble Engine Long
Engine modifications:
tti headers 1-7/8" primaries to 2" collectors.
tti exhaust system 2-1/2" with X-Pipe.
Dynomax super turbo muffler system with 2-1/2" stock appearing tips.
Viscus fan package.
70watt power-master amp
It has it's original Carter VAS 4bbl (rebuilt)
Estimated 400hp and 500lbs of torque.
Transmission:
TorqueFlite-727
Gear Vendor Over drive (6 speed)
Trans-Go TF-2 (as you suggested)
Rebuilt
Rear End:
8-3/4" SureGrip with new Auburn gears (30% bigger) 489 case with 7290 Yoke.
3.91 gears at this point, "may" down size to 3:55's.
Anything else, just ask mate.  :swaying:
« Last Edit: June 24, 2006 - 11:59:00 AM by Rev-It-Up »
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Carlwalski
Re: Chryco's NZ Engine Build
« Reply #1 on: March 15, 2006 - 02:05:57 AM »
Just remembered, check the engine shops build remarks:
"Remarks: Smooth idle, approximate RPM power range 1500 to 5000 plus. Excellent low-end torque with good mid-range hp. Increased compression ratio may be required for maximum output. Designed to improve performance plus economy."
« Last Edit: March 15, 2006 - 02:08:05 AM by NZ440R/T »
Offline matt63
« Reply #2 on: March 15, 2006 - 07:14:49 PM »
It sounds like you've got a nice stock engine rebuild.  I'm not sure about your cam selection though.  A stock hp 440 peaked at 375 hp with the 10.5:1 advertised compression ratio.  If you check the specs I think that you will find the cam in these hp 440's had more duration and lift than the specs you list (approx 268/284 duration and 0.450/0.458 lift).  Of course more modern grinds are available from Comp Cams, Ultradyne, Hughes, etc.
Matt in Edmonton
'68 Valiant
Offline dimples
  • (dodgetkboy78)
    • American car and truck forums
« Reply #3 on: March 15, 2006 - 07:24:54 PM »
Bet she runs real smooth NZ, why change it? Changing the cam might not give it much more power, unless you're looking fo rthe lope, you may want to leave her alone.
Offline Carlwalski
« Reply #4 on: March 15, 2006 - 07:28:40 PM »
Thanks guys, she does run real smooth and leaving it as-is is definitely an option.
There is enough power for me there est 400hp.
Chryco noticed the cam in a heart beat and is going to recommend a good cam for my combo.
Thanks Dimples and Matt.  :cheers:
Offline dimples
  • (dodgetkboy78)
« Reply #5 on: March 15, 2006 - 07:37:59 PM »
*wispers in ear* "Dont fix what ain't broke"
 :popcorn: :icon16: :wave:
« Reply #6 on: March 16, 2006 - 01:10:09 PM »
just waiting on piston info if you can get it
Offline Carlwalski
« Reply #7 on: March 16, 2006 - 04:22:59 PM »
Sweet as am going in today to see what I can find out.  :thumbsup:
Offline Carlwalski
« Reply #8 on: March 17, 2006 - 02:16:50 AM »
Chryco....I can't get any info on the pistons mate. Sorry, that sucks, I know.  :crying: :pullinghair:
All I askd them to do was rebuild it stock and give it a bore of 0.30 over to clean out the 35+ year old chambers.
When changing the cam does that also require piston upgrade?
Or are you wanting to know piston info to pick the ideal camshaft for my pistons?  :dunno:
 :wave:
« Reply #9 on: March 17, 2006 - 10:52:17 AM »
just trying to make sure you have enough piston to valve clearance , so no you don`t need to change pistons
