Author Topic: Which Carb in 71 383 car?  (Read 1403 times)
Offline A383Cuda
    • Sal's Muscle Cars
« on: March 18, 2006 - 12:21:34 AM »
I have a Holley double pumper (appears to be factory?) in my 71 383 automatic 727 car. I am starting to have problems with it, probably needs rebuilt. I am just wanting to make sure it's the correct carb for the car before I go throwing money at it. I have seen that some cars use a thermoquad or carter afb setup. Can anyone tell me which is correct for my car? Thanks! Sal
Re: Which Carb in 71 383 car?
« Reply #1 on: March 18, 2006 - 01:33:44 AM »
the 383 was avaiable from the factory with either a Carter AVS or the Holley 600 4 bbl non double pump style
 get the list # from the choke flange to be sure it is correct
Offline tancuda
« Reply #2 on: March 18, 2006 - 10:36:21 AM »
71 383 4bbl cuda came with holley carb :
List #R4668A for automatic
List #R4735A for automatic with shaker.
You can use a Carter too but remember both carb use different fuel
line from pump to carb (if you buy pre-bent line), and different
thermostatic choke assembly. (if you intend to use it)
I think you'll have less trouble with these carb when using stock air cleaner.
 :wave:
Offline A383Cuda
    • Sal's Muscle Cars
« Reply #3 on: March 19, 2006 - 09:23:34 AM »
Thanks guys! I will check my carb numbers. Is this R4668A a casting number on the carb or what number should I be physically looking for on it? I would definitely like to stick with the Holley setup as it all apears to be factory linkage. Thanks!
« Last Edit: March 19, 2006 - 09:31:00 AM by A383Cuda »
« Reply #4 on: March 19, 2006 - 01:36:48 PM »
it is the list # stamped into the choke horn
