Author Topic: Wiring Diagram......73 340  (Read 2787 times)
Offline cuda-cable
  • MOPAR or no car
« on: March 18, 2006 - 12:23:33 PM »
Can  someone point me to a web  site where I  can get a wiring diagram  for my engine bay,  or good pictorials.  I've got no problem  with the headlites, signals , etc.........have some wires thou such as alternator, and coil? in question.  Also  I have this  Mallory ignition system (have the wiring diagram so no problem there) and the car  had this  I'll call it a 'single' coil ballast resister?  which is not what I'm  familiar with since other DCX  vehicle I' ve  worked on had a 'dual coil' setup? What /why  is it different? ..........thx  for any help.........dk
Re: Wiring Diagram......73 340
« Reply #1 on: March 18, 2006 - 12:35:06 PM »
dual ballast resistors were used to drop voltage to the 5th pin on the ign ECU , no ign boxes have been made with the 5 th pin since around 76 , the voltage is dropped internally instead so using a dual ballast is redundant as the second resistor is never used
 you should have a blue wire to 1 side of the ballast & a brown to the other side & 1 wire usually blue [ sometimes brown]  from the ballast to the coil , then the black/ yellow wore from coil - to the ign ECU
 Alt shouls have 1 heavy black wire for power output & a blue 12v wire to feild & a green wire from the feild to the voltage regulator , the 2 feild connectors can be plugged into either terminal on the alt
Offline R/T
  • Johnson City TN
« Reply #2 on: March 18, 2006 - 02:00:41 PM »
 Is this what you need?
« Last Edit: March 18, 2006 - 02:02:55 PM by 71R/T »
1973 Challenger (OO/=====\OO)  440
Hemis and Harleys
2008 Dodge Ram Big Horn Edition  5.7 Hemi
Offline cuda-cable
  • MOPAR or no car
« Reply #3 on: March 18, 2006 - 11:13:45 PM »
Another question  re; the 'fuseable link' ....in-line  close to the battery.......how do you test it?  Can it be replaced by say a 30amp  in-line style  fuse?.......thx...dk
« Reply #4 on: March 18, 2006 - 11:19:14 PM »
test it with a volt meter , if it has 12v on the side away from the battery it i sworking , I got a replacement fuseable link from a local parts store & so;dered & heat shrunk 1 end
« Reply #5 on: March 19, 2006 - 05:03:29 AM »
That's an interesting thought about replacing it with a fuse. I'm just not sure what the fuseable linkage is rated at. I could be wrong, but the difference I believe is that a fuse will blow instantly, where the linkage might cook a little before it gives up. I smoked one real good one time. Don't ask me how.  :banghead:  :banghead:  :banghead:
