The K frame will come out as a complete assembly once you've backed off the torsion bar adjustment bolts and removed the torsion bars. You'll also need to remove the upper control arm bushing bolts and the steering coupler, that's pretty much it other than the four big bolts holding it all in. After you've backed out the torsion adjusting bolts, remove the little spring clips in the end of the torsion bars in the cross member, then using a clamping device, (I used a home made clamp out of 1" copper pipe and vice grips) and tap back the torsion bars from out of the lower control arms, (do not gouge the bars!) You may need to support the steering assy on each side as you do this so the weight hanging on them will not hinder you removing the bars. I suppose if you don't mind messing with the added weight and bulkiness of the torsion bars, they will come out the front of the cross member but it's a real pain in the arse, easier just to pull the torsions in the beginning. Hope you can get it, it's not a bad job.
