Author Topic: 5-spd install.  (Read 3829 times)
Offline BIG MIKE
5-spd install.
« on: February 27, 2003 - 09:21:37 PM »
i found this and thought i would share
http://users.anet.com/~sdurr/trans1.html
is anybody else thinking about doing this?
Re:5-spd install.
« Reply #1 on: February 28, 2003 - 01:50:24 AM »
 well considering the 833 OD is about as strong & is similar in top & bottom gear ratios I will save $3200 & bolt in the 833 thanks  ;D
Offline cuda
  • 1970 340 Cuda, pistol grip 4 speed,3:91 sure grip
Re:5-spd install.
« Reply #2 on: February 28, 2003 - 07:54:36 AM »
Hey big Mike, the 833 OD is the way to go as Niel said. I put one in my Cuda last year and am more that happy with it :) I have 3:91 gears and have awesome bottom end and still have not found top speed :o Was messing with 130 mph and had more to go but was a little to afraid ::) Cuda Brian
Offline 68cuda
  • 68 Cuda with 'Attitude'
Re:5-spd install.
« Reply #3 on: January 11, 2004 - 06:16:40 PM »
Hey, I just read this message and was curious to know how the OD unit is holding up?  I have a 68 Cuda that I am restoring.  I have and 833 OD unit, but am a little concerned about the wide spread with the gears.  Has some thoughs of using the Gearvendors unit or going with the Tremec unit.
Re:5-spd install.
« Reply #4 on: January 12, 2004 - 01:35:27 AM »
The ODs have held up fine for me , why spend 10x the $$
Offline mikes68charger
  • I'm a llama!
Re:5-spd install.
« Reply #5 on: January 12, 2004 - 09:39:51 AM »
I hate to say this but I was think of a kellers 5 speed also.  BUT  I got a book about Dodge Chargers history. There was an artical in this book that used 2 identical 383 Charger. The only dif was one had a 3 speed and one had the 4 speed. From what I understand the 3 speed has basicly the same gear spread as the 833 od.  In all the drag test the 3 speed only came in .10 -.20 slower than the 4 speed trans.   This pluse the help of Chryco Psycho
Offline 68cuda
Re:5-spd install.
« Reply #6 on: January 12, 2004 - 12:32:29 PM »
Thanks Guys, by the way, what kind of engines are you using in your rigs?  Curious to know the HP/Torque you are pushing through the 833 OD unit.
Offline Pistol Gripper
Re:5-spd install.
« Reply #7 on: January 12, 2004 - 01:43:36 PM »
I am planning on putting an 833OD in both the Challenger and the Road Ruster.  Anyone know of a good source for rebuilding info?  I figure I should go through them before I use them.
P.G.
O ne
B ig
A $$
M istake
A merica
Offline 68cuda
Re:5-spd install.
« Reply #8 on: January 12, 2004 - 08:24:10 PM »
I might be able to point you to a few pieces of information that I found.  Here's a link to a web page that outlines some interesting facts about the 4 speed and basics on rebuilding.
http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
It also has information on a couple of articles written by Rick Ehrenberg on the 833.  Other than that, check out any tech manual.
Re:5-spd install.
« Reply #9 on: January 13, 2004 - 03:16:59 AM »
I used the OD behind my 525 Hp 440 & raced it for 9 years , I didn`t have a trailer & the track was 2 hours away [at 70 mph], I broke 3 8 3/4 diffs & pulled the wheels 2-3 ' every launch at between 55-6500 rpm
Offline 68cuda
Re:5-spd install.
« Reply #10 on: January 13, 2004 - 10:04:49 AM »
Well, that certainly boasts that the 833 OD will take the abuse.  I'll give it a shot and see how it goes.  Thanks for the input.
Offline greenmachine
Re:5-spd install.
« Reply #11 on: January 15, 2004 - 06:20:50 PM »
hey cuda, what kind of rpm do you turn at 70 mph? I really like the sound of being able to cruise on the highway, without having to spend 3000$ on a 5 speed
Out of curiosity, what were you turning when you got your car up 130? :)
While you ford and chevy guys are arguing, the Dodge boys are waiting at the finnish line for you to hurry your asses up.
Offline 1973challenger360
Re:5-spd install.
« Reply #12 on: January 16, 2004 - 12:03:50 PM »
my car is an auto and a od would be nice, what kind of rebuild would this need, parts ? and will this bolt up just like a non od 833 with a pistol grip ?
