zerftzen,
for everyday driving an open is the best. Going around turns it's the smoothest for all the pinion gears. With a posi, clutches are trying to break free to let the outside tire spin more than the inside one, when turning. For all out performance, noise, smoke, and traction, the posi is better. How ofter has your open rear end smoked both tires? When the streets are wet or dry and you want to power slide the rear end around a corner, the posi wins everytime. But let's say your mom is driving your car around a turn and she suddenly hits a slick spot, one tire spinning is alot better for her than both tires spinning and spinning her around. So what that means is for that older guy that likes open rear ends, he knows his limits and doesn't power slide his car anymore. What type of guy are you?
To get back to the topic, the locker is good because it only locks under power and acs like an open when not needed. The older ones used to Click going around turns. Like a ratchet. I saw one on Hot Rod TV that energizes like a posi when 12v is applied to a coil in the pumpkin. Nice piece.
