Newbie question-how to change front side marker bulbs?
Author Topic: Newbie question-how to change front side marker bulbs?  (Read 1234 times)
Offline scf100
  • FAST LANE FOREVER!
« on: March 22, 2006 - 08:02:02 PM »
Have a 70 Challenger and I want to change the light bulbs on the front side marker lights. The wiring is fragle so did not want to pull too hard....I thought you just pulled the socket out from the backside right?
thanks, Stuart
1970 Challenger R/T convertible 383…. 4-speed…3.91 suregrip
Triple Black
Offline 70RTdroptop
  • 1970 Challenger R/T 440-SixPack
Re: Newbie question-how to change front side marker bulbs?
« Reply #1 on: March 22, 2006 - 10:09:21 PM »
You need to remove the entire bezel. Pull the turn signal wire connectors apart from the main wiring harness, then undo the 2 nuts on the back side of the bezel backing plate. That releases the whole unit from the fender. Pull the whole bezel  out, on the backside are 2 screws holding the plastic lens in place. Unscrew them, pop the lens, and you've got access to the light bulb. Kind of a pain,but that's how it is. If you do break the wiring that connects to the bezel,don't worry. Repops are available. Just saw some on e-bay for like $29.00 or so. Hope this helps!
1970 Dodge Challenger R/T 440-6 convertible
1966 Ford Mustang convertible  - numbers matching (wife's car )
Offline scf100
« Reply #2 on: March 22, 2006 - 10:41:32 PM »
Thanks, wondered why it was so hard when the rears just pop out....
Triple Black
